Patch artifact download links
This page provides the download links for the artifacts required to apply a patch.
2024.10.3 patches
This section provides the download links for the artifacts required for Automation Suite on Linux 2024.10.3 patches.
2024.10.3+patch2
as-images.txt
To download as-images.txt for Automation Suite 2024.10.3+patch2, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch2/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2024.10.3+patch2, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch2/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.3+patch2, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch2/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.3+patch2, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch2/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2024.10.3+patch2, take one of the following steps:
  • To download the full as.tar.gz, run the following command:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch2/as-2024.10.3+patch2.tar.gz
  • To download the split as.tar.gz, run the following command:
    https://download.uipath.com/automation-suite/2024.10.3+patch2/as-2024.10.3+patch2-part-001
    https://download.uipath.com/automation-suite/2024.10.3+patch2/as-2024.10.3+patch2-part-002
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2024.10.3+patch2, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch2/as-fs-2024.10.3+patch2.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2024.10.3+patch2, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2024.10.3+patch2/docker-images.json
versions.json
To download versions.json for Automation Suite 2024.10.3+patch2, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2024.10.3+patch2/versions.json
2024.10.3+patch1
as-images.txt
To download as-images.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2024.10.3+patch1, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch1/as-2024.10.3+patch1.tar.gz
    https://download.uipath.com/automation-suite/2024.10.3+patch1/as-2024.10.3+patch1-part-001
    https://download.uipath.com/automation-suite/2024.10.3+patch1/as-2024.10.3+patch1-part-002
    https://download.uipath.com/automation-suite/2024.10.3+patch1/as-2024.10.3+patch1-part-003
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2024.10.3+patch1, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch1/as-fs-2024.10.3+patch1.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2024.10.3+patch1, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2024.10.3+patch1/docker-images.json
versions.json
To download versions.json for Automation Suite 2024.10.3+patch1, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2024.10.3+patch1/versions.json
2024.10.2 patches
2024.10.2+patch1
as-images.txt
To download as-images.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/embedded-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/hydrate-registry.sh
as.tar.gz
To download as.tar.gz for Automation Suite 2024.10.2+patch1, take one of the following steps:
    wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.2+patch1/as-2024.10.2+patch1.tar.gz
    https://download.uipath.com/automation-suite/2024.10.2+patch1/as-2024.10.2+patch1-part-001
    https://download.uipath.com/automation-suite/2024.10.2+patch1/as-2024.10.2+patch1-part-002
    https://download.uipath.com/automation-suite/2024.10.2+patch1/as-2024.10.2+patch1-part-003
as-fs.tar.gz
To download as-fs.tar.gz for Automation Suite 2024.10.2+patch1, run the following command:
wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.2+patch1/as-fs-2024.10.2+patch1.tar.gz
docker-images.json
To download docker-images.json for Automation Suite 2024.10.2+patch1, run the following command:
wget -O docker-images.json https://download.uipath.com/automation-suite/2024.10.2+patch1/docker-images.json
versions.json
To download versions.json for Automation Suite 2024.10.2+patch1, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2024.10.2+patch1/versions.json
  • 2024.10.3 patches
  • 2024.10.3+patch2
  • 2024.10.3+patch1
  • 2024.10.2 patches
  • 2024.10.2+patch1
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
