- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Reference for additional backup and restore configuration options in Automation Suite, including NFS server update considerations.
Repaving or updating the NFS server
UiPath® does not provide any specific steps to repave or update the NFS server.
Before updating the NFS server, make sure the backup is disabled. For instructions, refer to Backing up the cluster.
Guidelines
It is good practice to back up the disk attached to the NFS server where you create the backup. You can find this information defined as the
nfs.mountpointkey in thebackup.jsonfile. -
To repave the NFS server, take the following steps:
- Mount the backup disk on the newly repaved machine on the same mount point as defined by the
nfs.mountpointkey in thebackup.jsonfile. - Update the NFS endpoint of the new NFS server defined as
nfs.endpointinbackup.json. - After repaving the NFS server, make sure you have followed the Setting up the external NFS server guidance.
Once the update to NFS server is complete, it is recommended to reboot the machine. Also make sure to enable the backup on cluster. For instructions, refer to Backing up the cluster.
Adding a new node to the cluster
To add a new node to the cluster, re-run the following steps:
- Add the FQDN or the IP address of the new node to the allowlist of the NFS server. For instructions, refer to Allowing NFS mount path access to all backup and restore nodes.
- Enable the backup on the new node post-installation. For instructions, refer to Backing up the cluster.
