Last updated Dec 19, 2025
Optional: Passing custom resolv.conf
The Kubernetes cluster that Automation Suite deploys uses the name servers configured in /etc/resolv.conf. Kubernetes does not work with local DNS resolvers (127.0.0.1 or 127.0.0.0/8), so if you have such name servers configured in /etc/resolv.conf file, you need to pass a file reference with the correct nameserver entries accessible from anywhere on the VM in the .infra.custom_dns_resolver parameter in cluster_config.json.
For details on a known limitation, see Kubernetes documentation.
Optional Parameters
Path to the file with correct name server entries that can be accessed from anywhere on the VM. These name server entries must not be from 127.0.0.0/8.
