  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
    • 2024.10.7
    • 2024.10.8
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
Automation Suite release notes
Last updated Apr 14, 2026
2024.10.3
Release date: April 28, 2025
Support for new RHEL version
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Release date: September 24, 2025
Kerberos keytab rotation does not trigger token regeneration
Erratum - added September 24, 2025: An issue causes Kerberos keytab rotation to not immediately regenerate authentication tokens, which may lead to temporary connectivity disruptions between services and the database.
To address the issue, you must manually trigger the Kerberos ticket renewal cronjob by running the following command:
kubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipath
We fixed the issue in Automation Suite 2024.10.5.
Orchestrator does not start when using user-assigned managed identity
Erratum - added September 24, 2025: An issue prevents the storage.useClientID parameter from being set when you select a user-assigned managed identity for object storage. As a result, Orchestrator cannot start in environments where access is restricted to user-assigned managed identities.
To address the issue, you must manually set the parameter in ArgoCD, as follows:
  1. In the ArgoCD Orchestrator application, go to Details > Parameters.
  2. In the values text box, set storage.isExternal : true and save.
Temporary registry installation timeout
Erratum - added September 24, 2025: An issue causes the temporary registry installation to fail with a timeout error when connecting to registry-1.docker.io. To address the issue, refer to the Troubleshooting section.
Thanos compactor stops on corrupted blocks
Erratum - added September 24, 2025: An issue causes the Thanos compactor to stop compacting metrics when it encounters corrupted blocks in the object store. This prevents compaction and leads to increased storage usage.
Generating the configuration file using a GUI-based wizard
Navigating through the intricacies of a platform configuration, involving multiple flags and parameters, can at times be a challenging experience. To simplify this, we bring you the Automation Suite Installer Wizard, a new method for generating the Automation Suite cluster_config.json configuration file.
This GUI-centric tool guides you through the key configuration steps, prompting you to provide details about your Automation Suite installation. It requires details such as the targeted platform, environment type, storage needs, SQL database specifics, and more, subsequently generating the cluster_config.json file for you.
PostgreSQL for Process Mining Airflow database
For Process Mining on Automation Suite 2024.10.3, you can now choose to use PostgreSQL for the AutomationSuite_Airflow database. If you choose not to use PostgreSQL and keep using Microsoft SQLServer, Process Mining on Automation Suite 2024.10.3 will run with a legacy version of Airflow.
Refer to SQL Requirements for Process Mining for more information on how to set up a PostgreSQL AutomationSuite_Airflow metadatabase.
Important:
You are recommended to move to PostgreSQL for the Airflow database, as PostgreSQL runs with the latest versions of Apache Airflow. Latest versions of Apache Airflow have various functionality, performance, and security fixes that older versions lack.
Removed Dapr dependency for Process Mining
Starting with Automation Suite 2024.10.3, Process Mining will no longer have a dependency on Dapr.
Task-Mining, however, will still continue to have a dependency on Dapr.
If you are installing Automation Suite where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will not be installed.
In case of an Automation Suite upgrade where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will be automatically uninstalled.
Additional custom CA certificate support
You can include any additional custom CA certificate by providing the additonal_ca_certs key with the external CA certificate path in the cluster_config.json file.
Enhanced telemetry
Enhanced Automation Suite with a high-level summarized usage telemetry feature, provided guidance on viewing the generated XML file, and added telemetry sharing with UiPath Support via the Customer Portal.
Istio HSTS enabled by default
To enhance security, Istio HSTS is now enabled by default.
uipathctl improvements
  • You can now list all the available options for the included and excluded flags when running the prerequisite checks command. For more details about --list-options, refer to the uipathctl reference guide.
  • For better eficiency, the diagnostic checks are no longer executed during the bundle creation process. Previously, a health check was performed by default during the support bundle creation, requiring the explicit use of the --skip-diagnose flag to bypass it. For more details on how to run the diagnostic checks, refer to the uipathctl reference guide.
Bug fixes
  • Resolved an issue where proxy and Kerberos-based pipelines were not functioning correctly in Automation Suite 2024.10.0, 2024.10.1, and 2024.10.2. This issue has been fixed, restoring proper support for proxy and Kerberos authentication in pipelines.
  • An issue related to Velero migration caused the Automation Suite in-place upgrade to 2024.10.1 and 2024.10.2 to fail when the backup was enabled. We have fixed the issue.
  • An issue was causing the node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, to not work for specific nodes such as GPU, task-mining, or as-robot. We have fixed the issue.
  • Previously, the configuration of user authentication and SQL authentication for the Automation Suite cluster was interconnected. To use either of them, you had to set both kerberos_auth_config.enabled and kerberos_auth_config.enable_integrated_sql_auth parameters to true. Currently, we allow independent configuration of only user authentication by setting kerberos_auth_config.enabled to true and kerberos_auth_config.enable_integrated_sql_auth to false. Independent SQL authentication is still not supported.
  • We have fixed an issue causing the side-by-side and the in-place upgrade of Automation Suite 2022.10 or earlier to Automation Suite 2024.10.0 or later to fail when Apps was enabled and you used Kerberos authentication for the SQL Server database.
  • An issue was preventing the registry cleanup command from effectively clearing the unused Docker images from all registry pods. We have fixed the issue.
  • We have fixed an issue that blocked the Automation Suite upgrade on a backup-restored cluster.
  • We have resolved an issue causing the health check command to fail in offline environments. The issue occurred due to the incorrect parsing of Istio image versions from registries containing two or more semicolons.
  • We have fixed an issue that was causing Studio Web to throw a 404 error when using a proxy environment.
Known issues
Custom platform database name not supported when installing Process Mining
Erratum - added March 26, 2026: When Process Mining is enabled, using a custom platform database name causes the OMS backfill job to fail.
As a workaround, use AutomationSuite_Platform as the platform database name when installing Process Mining.
Prerequisite check incorrectly validates monitoring and logging components
Erratum - added March 26, 2026: The prerequisite check incorrectly validates monitoring and logging components. Since these components are installed after the prerequisite phase, this validation is not necessary.
We fixed the issue in Automation Suite 2024.10.8.
Insights real-time monitoring not working on the secondary cluster in Active/Active deployments
Erratum - added March 26, 2026: In Active/Active deployments with Insights real-time monitoring enabled, Orchestrator and platform services on the secondary cluster do not push real-time monitoring data due to configuration issues with call redirection from the secondary cluster to the primary cluster.
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
AI Center in-cluster proxy connectivity issue
Erratum - added December 19, 2025: An issue prevents AI Center pods from connecting to the in-cluster object store in proxy-enabled environments. This occurs due to unsupported CIDR notations and FQDN regex patterns in the no_proxy configuration.
We fixed the issue in Automation Suite 2024.10.7.
Prerequisite checks fail when Process Mining is enabled
Erratum - added December 19, 2025: An issue causes the prerequisite checks to fail when Process Mining is enabled. The issue occurs due to the checks still requiring cert-manager, although cert-manager is no longer needed for Process Mining starting with Automation Suite 2024.10.3.
The failure message is a false positive and can be safely ignored.
Pre-upgrade command fails with proxy and external objectstore
Erratum - added December 19, 2025: An issue prevents the uipathctl cluster pre-upgrade command from completing successfully in environments configured with a proxy and external objectstore. The issue occurs due to an error during the Insights volume migration process.
Upgrade failure during posthook import in chained upgrades
Erratum - added December 19, 2025: An issue causes the upgrade to fail during the execution of the uipathctl rke2 upgrade command in chained upgrade scenarios. This issue occurs due to the posthook secret and configmap import operation not being idempotent, which leads to conflicts with existing Kubernetes objects.
Backup operations fail with PartiallyFailed status
Erratum - added December 19, 2025: An issue causes backup operations to fail with a PartiallyFailed status when the objectstore is in-cluster (rook-ceph).
The backup logs show errors similar to following example:
ERROR: insights/app/workdir/2025-10-01-04/.config/chromium/Crash Reports/settings.dat: Failed to copy: failed to open source object: operation error S3: GetObject, https response error StatusCode: 404
You can view the backup logs by running the following command:
./bin/velero backup logs <backup name>
To address the issue you must contact UiPath Support.
We fixed the issue in Automation Suite 2024.10.4.
Registry certificates not fully updated in offline scenarios
Erratum - added September 24, 2025: An issue causes the uipathctl config tls-certificates command to update only the internal certificate, while missing the certificate required by Argo CD to trust the in-cluster registry in offline scenarios.
To address the issue, you must run the following command to explicitly update the ArgoCD registry certificate in internal–external registry scenarios:
./bin/uipathctl config argocd ca-certificates update --cacert [PATH]
Uploading large Document Understanding bundles causes node instability
Erratum - added July 17, 2025: An issue causes nodes to become unresponsive when uploading large Document Understanding offline bundles. The issue occurred due to image layers being loaded into memory in parallel, leading to high memory consumption and out-of-memory (OOM) errors.
GPU enablement fails with external registries containing project names
Erratum - added September 24, 2025: An issue prevents GPU enablement after adding a GPU node when using external registries with project names (such as Harbor). The required pods do not start and display an ImagePullBackoff error.
If you are using an external registry with a project name, update the NVIDIA device plugin daemonset with the following command:
# Replace REGISTRY_WITH_PROJECT_NAME with the correct value (Eg. my.registry.io:443/myproject)
# Replcae TAG with the correct value. You can get this from the <installer_directory>/versions/docker-images.json file (Eg. v0.17.1)
kubectl set image daemonset/nvidia-device-plugin-daemonset \
  -n kube-system \
  nvidia-device-plugin-ctr=<REGISTRY_WITH_PROJECT_NAME>/k8s-device-plugin:<TAG>
  -n kube-system \
Task Mining Kerberos initialization failure
Erratum - added June 26, 2025: An issue causes the Task Mining service to fail to initialize in Kerberos environments. This issue occurs when the kerberos-discoverygroup-user-keytab secret is missing or when the discoverygroup app is not included in the enabledApps parameter of the IntegratedAuth app.
Agent node addition failure in offline environments
Erratum - added June 26, 2025: An issue causes the addition process of agent nodes in offline environments to fail. Agent node additions require the temporary registry to be running. To address the issue, you must re-enable the temporary registry to successfully join the agent node.
Frequent restarts in uipath namespace due to secret mismatch
Erratum - added June 26, 2025: An issue causes frequent restarts of deployments in the uipath namespace due to inconsistent istio-ingressgateway-certs secrets between the istio-system and docker-registry namespaces.
Log streaming does not work in proxy setups
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
Installation fails due to CA certificates with large policy OIDs
Erratum - added June 26, 2025: An issue causes the Automation Suite installation to fail when using Certificate Authority (CA) certificates that include a CertificatePolicies section with policy OID values exceeding 4 bytes. This issue prevents Automation Suite from recognizing these CA certificates, interrupting the installation process.
To address the issue, you must either ensure that the policy OID values within the CertificatePolicies section do not exceed 4 bytes, or avoid using CA generators that add the CertificatePolicies section to the certificates.
Process Mining portal fails to load
Erratum - added June 26, 2025: After upgrading from Process Mining in Automation Suite 2024.10.2 to 2024.10.3, the Process Mining portal may fail to load the process apps. An HTTP Error (400) error message is displayed when attemptimg to access the Process Mining portal.
The issue can occur when VersionSetJson is set to
    "Main": "6.13.0",
    "Extra": ["6.17.0"]
    "Main": "6.13.0",
    "Extra": ["6.17.0"]
in the DetailsJson in the Process Mining AutomationSuite_ProcessMining_Metadata database, which breaks JSON serialization for the SemVersion object.
To solve the issue, execute the query that replaces "Extra": ["6.17.0"] with "Extra": [] in DetailsJson field in Ingestions table.
Important:
You need to have write access to the Process Mining AutomationSuite_ProcessMining_Metadata production database.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Service disruptions due to automatic secret rotation
Erratum - added June 26, 2025: To address this issue, you can edit the cluster_config.json file to disable secret rotation in the platform configuration. This change will persist through Automation Suite upgrades and reinstalls.
Take the following steps:
  1. Update the platform section in the cluster_config.json file as shown in the following example:
    "platform": {
      "enabled": true,
      "advanced_configuration": {
        "identity-service": {
          "secretRotation": {
            "enabled": false
    "platform": {
      "enabled": true,
          "secretRotation": {
            "enabled": false
  2. After applying this configuration, you must reinstall your Automation Suite deployment to ensure the change takes effect:
    ./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions ./versions/helm-charts.json
Erratum - added May 14, 2025: An issue causes service disruptions due to the automatic secret rotation, making services temporarily inaccessible.
To address this issue, take the following steps:
  1. Restart the affected service to restore its normal functionality.
  2. Navigate to the ArgoCD UI and from the platform applicatio, select Details > Parameters. Edit the values to add "secretRotation: enabled: false" under identity-service. You must take this step after each Automation Suite upgrade or reinstallation.
For AI Center, all skills must be stopped and started from AI Center UI.
Garbage collection fails during registry cleanup
Erratum - added September 24, 2025: An issue prevents garbage collection from executing correctly during in-cluster registry cleanup. This may result in unused images not being cleaned up as expected.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2024.10.3Automation Ops 2024.10.3AI Center 2024.10.3Action Center 2024.10.3
Task Mining 2024.10.3AI Computer Vision 2024.10.3Insights 2024.10.3Apps 2024.10.3
Process Mining 2024.10.3Document Understanding AI Center-based projects 2024.10.3
Document Understanding modern projects 2024.10.3
Orchestrator 2024.10.5
Test Manager 2024.10.3
Data Service 2024.10.3
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.31.4+rke2r1
ArgoCDv2.14.4
gatekeeper3.18.2
rook1.16.1
ceph19.2.0
prometheus-pushgatewayv3.0.0
cert-managerv1.17.1
kube-logging/logging-operator5.2.0
kube-logging/config-reloaderv0.0.7
istio1.25.0
velero1.15.2
reloaderv2.0.0
Prometheusv3.2.1
Grafana11.5.2
redis-operatorv7.8.4-9
redis-clusterv7.8.4-95.focal
oauth2-proxyv7.8.1
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
