Automation Suite on Linux Installation Guide
Last updated Feb 7, 2025
Step 2: Deploying Automation Suite to GCP Marketplace
Configuring the deployment
To configure the deployment, provide details such as the service account, region, zone, installer version, server and agents, services, and then select Deploy to complete the operation.
Note:
If you run the deployment but uncheck the Perform installation checkbox, you must install Automation Suite manually after the deployment concludes. For manual installation instructions, see Manual: Preparing the installation.
Completing the deployment
To ensure the deployment was successful, we recommend checking the deployment status.
  • Configuring the deployment
  • Completing the deployment
