- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated Dec 19, 2025
- Virtual network
- A subnet where all nodes reside.
- A NAT Gateway for outbound connectivity (a Cloud Nat resource attached to a Cloud Router);
- Firewall Rules to secure subnet traffic.
- A DNS private zone needed for installation. For more details, check the Known limitations section.
- 4 Managed Instance Groups. You can choose the instance type for server, agent, GPU agent nodes, and Automation Suite Robots
nodes. Make sure you meet the hardware requirements for each type of node. Each VM has a 128 GB OS and 256 GB cluster binaries and state disk. Server nodes have two additional
disks: a 512GB data disk and a 512GB disk used for objectstore.
- Server nodes (cluster control plane). Server nodes also run workloads.
- Agent nodes. Designed to only run workloads (they have no control plane services). If the number of desired Agent nodes is 0, an empty Managed Instance Group is created.
- GPU nodes. Nodes used specifically for ML models that have video cards. If the number of desired GPU nodes is 0, no Managed Instance Group is created.
- Automation Suite Robots nodes. Designed to only run robot workloads. If the number of desired Automation Suite Robots nodes is 0, an empty Managed Instance Group is created. Automation Suite Robots nodes have an additional 32GB disk used for robot package caching.
- Public load balancer used to balance HTTPS traffic from port
443to nodes. - 2 Internal load balancers and a Managed Instance Group needed for forwarding node registration requests. The VMs have the smallest instance size possible.
- Task Mining node deployed as a separate VM. Its instance type is n2-standard-32.
- Bastion instance used to access the other nodes. It has a public IP and SSH enabled.
- SQL Database Instance:
- 8 cores and 32 GB RAM
- 1000 GB disk size that can be manually extended
- The databases are created by the installer
A PostgreSQL Database Instance for Process Mining
AutomationSuite_Airflowdatabase. (Recommended for Process Mining on Automation Suite 2024.10.3 or higher)-
4 cores and 16GB RAM
64 GB disk size
>=500 IOPS
- A secondary SQL Database Instance is deployed if Process Mining is installed and the cluster is HA (has at least 3 server
nodes):
- 16 cores and 32 GB RAM
- 100 GB disk size that can be manually extended
- The database needed by Process Mining is created by the installer
- Secret Manager used to store auto-generated credentials for SQL server, Automation Suite Platform, and ArgoCD console.
Service account used for the VM identities.
Process Mining
Installation fails if you enable Process Mining in a multi-node HA-ready production mode. Make sure not to select Process Mining at installation time. You can enable Process Mining post-installation, after creating the
AutomationSuite_ProcessMining_Warehousedatabase. For details, see Managing products.
DNS
- Due to the fact that a DNS cannot be automatically attached to the LB:
- The steps for configuring DNS can be completed only after the installation, while they are needed during installation. The private DNS zone solves this issue and can be safely deleted after the installation is completed. Alternatively, for testing purposes check the Step 4: Configuring the DNS.
RHEL
- Google may update the RHEL version without notice, thus leaving Automation Suite deployments outside of support. Currently, manual deployments using custom RHEL images are the only way to and stay in support.
