- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
Rotating Blob Storage Credentials
To rotate the blob storage credentials for Process Mining in Automation Suite an administrator will need to have access to the Kubernetes cluster secrets using either kubectl, oc, lens, or another tool. The stored secrets detailed below must be updated with the new credentials, and the pods for Airflow and Process Mining need to be restarted to make sure all pods for these service receive the new credentials.
The storage credentials need to be updated in the UiPath namespace.
kubectl
kubectl patch secret processmining-external-storage-secret -n uipath -p "{\"data\":{\"ACCOUNTKEY\":\"<new_key_b64>\"}}"
UiPath Namespace
processmining-service-rook-ceph-secret.OBJECT_STORAGE_ACCESSKEY
processmining-service-rook-ceph-secret.OBJECT_STORAGE_SECRETKEY
UiPath Namespace
processmining-external-storage-secret.ACCESSKEY
processmining-external-storage-secret.SECRETKEY
UiPath Namespace
UiPath Namespace
processmining-external-storage-secret.ACCOUNTNAME
processmining-external-storage-secret.ACCOUNTKEY
urlencode -d "wasb%3A%2F%2Fazureuser%40%3Fextra__wasb__connection_string%3DDefaultEndpointsProtocol%3Dhttps%3BEndpointSuffix%3Dcore.windows.net%3BAccountName%3Dazureuser%3BAccountKey%3DACCOUNT_KEY%3BBlobEndpoint%3Dhttps%3A%2F%2Fexample.blob.core.windows.net%2F%3BFileEndpoint%3Dhttps%3A%2F%2Fexample.file.core.windows.net%2F%3BQueueEndpoint%3Dhttps%3A%2F%2Fexample.queue.core.windows.net%2F%3BTableEndpoint%3Dhttps%3A%2F%2Fexample.table.core.windows.net%2F%26extra__wasb__sas_token%3D%26extra__wasb__shared_access_key%3D%26extra__wasb__tenant_id%3D"
urlencode "wasb://azureuser@?extra__wasb__connection_string=DefaultEndpointsProtocol=https;EndpointSuffix=core.windows.net;AccountName=azureuser;AccountKey=ACCOUNT_KEY;BlobEndpoint=https://example.blob.core.windows.net/;FileEndpoint=https://example.file.core.windows.net/;QueueEndpoint=https://example.queue.core.windows.net/;TableEndpoint=https://example.table.core.windows.net/&extra__wasb__sas_token=&extra__wasb__shared_access_key=&extra__wasb__tenant_id="
