Last updated Nov 6, 2025
Performing post-installation operations
After completing the installation, you must perform a set of required configuration and enablement actions before starting to use the Automation Suite cluster.
  • If you are using a single-node cluster and have provisioned a Ceph backup disk, you must manually enable the Ceph backup CronJob. This job is not applied automatically during installation. For details, refer to How to schedule Ceph backup and restore data.
