- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Step 1.1: Creating the VM
Automation Suite on Linux Installation Guide
Last updated Jan 22, 2025
You need to have a resource group under your Azure subscription for running Automation Suite. If you want to use an existing one, you can skip this step and specify the resource group in the later steps.
- Go to the Azure portal.
- Search for Virtual Network from the home page and click Create.
All the machines that we provision should be part of this virtual network
- Type virtual machines in the search field.
- Under Services, select Virtual machines.
- In the Virtual machines page, select Create. The Create a virtual machine page opens.
You can configure the VM directly during the creation step under the Disks tab.
Important: Each machine needs to be added to the virtual network. For both single-node evaluation deployments or a multi-node HA-ready
production deployments, you need to create the virtual network. Each Azure VM resides in a Virtual Network (private network)
and the public IP is the way by which we are exposing it to external connections (internet).
Follow the steps below to create a new Virtual Network (or select the existing one) and Public IP address:
