- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Installation best practices
- Encrypting the SQL Server
- Performing database maintenance
- Performing yearly certificate maintenance
- Setting up directory roles and permissions
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 6, 2025
To grant permissions to a specific admin or regular user to access the Kubernetes cluster and RKE2 file, you must update the
sudoers file with the required settings.
The following section provides details on the files to which you must grant access to the admin or regular user.
/var/lib/rancher/rke2/bin/kubectlexecutable requires sudo access to operate on cluster resources. To grant the required permissions to the executable without a password, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL = NOPASSWD: /var/lib/rancher/rke2/bin/kubectlUSERNAME ALL = NOPASSWD: /var/lib/rancher/rke2/bin/kubectl /etc/rancher/rke2/stores the following files required to configure or access the cluster:-
/etc/rancher/rke2/config.yamlfile used to configure the cluster. The default permission for this file is-rw-r--r--. To allow users to modify/etc/rancher/rke2/config.yaml, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/config.yamlUSERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/config.yaml -
/etc/rancher/rke2/rke2.yamlfile used along with thekubectlcommand to operate on the cluster. The default permission for this file is-rw-------.To allow users to operate on the cluster, update thesudoersfile accordingly. For details, see the following configuration sample:Defaults!/var/lib/rancher/rke2/bin/kubectl env_keep += KUBECONFIGDefaults!/var/lib/rancher/rke2/bin/kubectl env_keep += KUBECONFIG -
/etc/rancher/rke2/registries.yamlfile required to configure the registry for the cluster. The default permission for this file is-rw-r--r--.To allow users to modify/etc/rancher/rke2/registries.yaml, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/registries.yamlUSERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/registries.yaml
/var/lib/rancher/rke2/directory stores the cluster related data, which includes kubelet logs, containerized data, static pod configuration files, RKE2 certificates, and etcd data. Admins may be required to read the file and check the size of the directory. To do this, you must give the required permissions to thels,cat, andducommands. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/bin/ls /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/cat /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/du /var/lib/rancher/rke2/*USERNAME ALL=NOPASSWD: /usr/bin/ls /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/cat /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/du /var/lib/rancher/rke2/*
Note:
For maintenance purposes, we recommend creating a separate file under the
/etc/sudoers.d/ directory with the configuration described on this page.
