- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
This page lists the steps you need to take before deploying Automation Suite to AWS.
To prevent data loss, ensure the infrastructure you use does not automatically delete cluster disks on cluster reboot or shutdown. If this capability is enabled, make sure to disable it.
The AWS deployment requires a moderate level of familiarity with AWS services.
If you are new to AWS, you can start by reading the following introductory materials to get familiar. They provide basic materials for how to design, deploy, and operate infrastructure and applications on the AWS Cloud.
This deployment also assumes familiarity with AWS Services listed in the Request resources quotas section of this guide. For a detailed diagram and description of the architecture, see:
If you don’t already have an AWS account, create one by following the step-by-step instructions. Your AWS account is automatically signed up for all AWS services. You are charged only for the services you use.
The following sections walk you through the steps you need to take to configure your AWS Account specific to the Automation Suite deployment requirements.
Amazon EC2 key pairs
You need at least one EC2 key pair in the AWS account in the Region where you will deploy the AWS Marketplace offering.
To create a key pair, see Amazon EC2 key pairs and Linux instances.
Take note of the key-pair name as it is needed during the deployment.
Valid domain name
This deployment requires you to have established ownership of the parent domain under which the web application will be served. If you want to register a domain, see Registering a public domain.
If you have registered the domain using AWS Route 53, then the hosted zone is preconfigured, and no additional configuration is necessary.
Otherwise, you should set up a hosted zone in your AWS account, with the required name server, start of authority, CNAME, and text records. For further details on how to create a public hosted zone, see Working with public hosted zones.
WaitConditionHandle resource in the routing
stack. The Physical Id of this resource is an URL. Execute a
POST request as described here.
Request resource quotas
If necessary, request service quota increases for the following resources. You might need to request increases if your existing deployment currently uses these resources and if the AWS Marketplace deployment could result in exceeding the default quotas. The Service Quotas console displays your usage and quotas for some aspects of some services.
For more information, see What is Service Quotas? and AWS service quotas.
Resource |
Requirement |
VPCs |
1 |
Subnets |
Up to 6 |
NAT gateways |
2 |
VPC endpoints |
1 |
Internet gateways |
1 |
Elastic IP addresses |
Up to 6 |
AWS Identity and Access Management (IAM) security groups |
1 |
IAM roles |
Up to 7 |
Auto Scaling groups |
Up to 2 |
Application Load Balancers |
Either 0 or 1 |
Network Load Balancers |
Either 1 or 2 |
Public certificate authorities (CA) |
1 |
Hosted zone |
1 |
RDS instances |
1 |
Bastion hosts |
1 |
Secrets |
4 |
Parameters in Parameter Store |
3 |
SSM documents |
Either 0 or 3 |
Lambda Functions |
3 |
Instance Profiles |
2 |
Security Groups |
3 |
Supported AWS regions
In order for the AWS Marketplace deployment to work in a Region other than its default Region, all the services that are part of the deployment must also be supported in that Region.
For an up-to-date list of AWS Regions and the AWS services they support, see AWS Regional Services.
Unrecognized resource
type error, then the deployment is not supported in that Region.
IAM permissions
Before launching the AWS Marketplace deployment, you must sign in to the AWS Management Console with IAM permissions for the resources that the templates deploy. The AdministratorAccess managed policy within IAM provides sufficient permissions, although your organization may choose to use a custom policy with more restrictions.
For more information, see AWS managed policies for job functions.
For a complete list of roles and policies that the CloudFormation template creates, see Roles and policies.
The following table describes all the external endpoints that the service interacts with:
Requirements |
Details |
| AWS metadata service |
Provides details about your Amazon EC2 instance |
| AWS management APIs |
Used via AWS CLI or lambda functions |
| AWS bootstrap archive |
Used for services to provision and manage resources. Retrieved from the following URL:
https://s3.amazonaws.com/cloudformation-examples/aws-cfn-bootstrap-py3-latest.tar.gz |
| AWS CLI package |
Used for the command line interface to interact with AWS services from a machine. You can access the package from the following
URL:
https://awscli.amazonaws.com/awscli-exe-linux-x86_64.zip |
| AWS SSM Agent |
Used for managing instances via remote commands at scale. You can download the agent from the following URL:
https://s3.${AWS::Region}.amazonaws.com/amazon-ssm-${AWS::Region}/latest/linux_amd64/amazon-ssm-agent.rpm |
| AWS Cloudwatch Agent |
Used for collecting system and application logs for monitoring. You can download the agent from the following URL:
https://s3.amazonaws.com/amazoncloudwatch-agent/redhat/amd64/latest/amazon-cloudwatch-agent.rpm |
| Nvidia drivers |
Required for GPU-enabled VMs. You can get the drivers from the Nvidia repository. |
| External repository if used |
N/A |
| UiPath S3 buckets for templates / lambda functions usage / bash scripts for installation. |
N/A |
For more details, see Network requirements.
Connect AiCenter
to an external Orchestrator to true and provide
certificates for Orchestrator and Identity to the parameters listed in AWS Marketplace deployment parameters. For details on how
to obtain the certificates, see Chain certificates.
To encode the certificates in base64 format, run the following commands:
cat orchestrator.cer | base64 | tr -d '\n' > orchestratorCert
cat identity.cer | base64 | tr -d '\n' > identityCertcat orchestrator.cer | base64 | tr -d '\n' > orchestratorCert
cat identity.cer | base64 | tr -d '\n' > identityCertTo register AI Center to the external Orchestrator, you must run this SSM document.
The AWS template allows you to enable a backup at deployment time. By default, the backup interval is set to 90 minutes, and the retention interval is set to 72 hours. You can change the default values post-deployment.
You can only enable FIPS 140-2 on your machines after completing an Automation Suite installation. For instructions, see Security and compliance.
Insights does not support FIPS 140-2, and you must disable it for a successful installation.
