- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated May 11, 2026
CAUTION:
Note:
We perform garbage collection as part of registry cleanup. No write operations on the registry should be performed while it is running. Registry seeding (a write operation) occurs during Automation Suite install and upgrade, so cleanup must not be performed while these procedures are in progress.
In certain situations, the unused Docker images are not effectively cleared from all registry pods, even after running the registry cleanup command:
./bin/uipathctl registry cleanup --manifest versions/docker-images.json
To remove the remaining Docker images, you must run the following script:
#!/bin/bas
# Set the namespace if necessary
NAMESPACE="docker-registry"
# Get list of docker-registry StatefulSet pods
PODS=$(kubectl get pods -n $NAMESPACE -l app=docker-registry -o jsonpath='{.items[*].metadata.name}')
# Modify the docker-registry service selector to include traffic: allowed
echo "Modifying docker-registry service selector..."
kubectl patch svc docker-registry -n $NAMESPACE --type='json' -p='[{"op": "add", "path": "/spec/selector/traffic", "value": "allowed"}]'
# Loop through each registry pod one at a time
for POD in $PODS; do
echo "Processing pod: $POD"
# Add label traffic=allowed to the current pod
kubectl label pod $POD -n $NAMESPACE traffic=allowed --overwrite
echo "Label traffic=allowed added to $POD"
# Sleep is needed to allow the Kubernetes endpoint controller to properly
# register the newly labelled pod as a healthy upstream target
sleep 60
# Run the registry cleanup command
echo "Running registry cleanup on $POD..."
# Remove label traffic=allowed from the pod
kubectl label pod $POD -n $NAMESPACE traffic-
echo "Label traffic=allowed removed from $POD"
echo "Completed cleanup for $POD"
done
# Revert the docker-registry service selector modification
echo "Reverting docker-registry service selector..."
kubectl patch svc docker-registry -n $NAMESPACE --type='json' -p='[{"op": "remove", "path": "/spec/selector/traffic"}]'
echo "Cleanup process completed for all registry pods."
#!/bin/bas
sleep 60
done
