  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
Automation Suite release notes
Last updated Nov 6, 2025
2024.10.5
Release date: September 24, 2025
AI Units usage metrics available in support bundle tool
The Automation Suite support bundle tool now collects AI Units usage metrics if you use AI Center.
New RHEL version supported
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Bug fixes
  • We have fixed an issue that caused the temporary registry installation to fail with a timeout error when connecting to registry-1.docker.io.
  • We have fixed an issue that prevented log forwarding when using S3 endpoints in non-AWS format (that is, without .amazonaws.com in the URL), as the endpoint was not in the format expected by Fluentd.
  • We have fixed an issue causing a delay in Kerberos keytab rotation, which prevented immediate regeneration of authentication tokens and occasionally disrupted database connectivity for services.
  • We have fixed an issue where the uipathctl config tls-certificates command did not update the registry certificates in ArgoCD for the in-cluster registry in offline scenarios.
  • An issue prevented the required pods from being created when enabling GPU after adding a GPU node. This issue occurred only when using external registries with project names ( such as Harbor). We have fixed the issue.
  • An issue prevented the installer from setting the storage.useClientID parameter when you selected a user-assigned managed identity for object storage. As a result, Orchestrator did not use your configured client ID, and in environments where access was restricted to user-assigned managed identities, Orchestrator could not start. We have fixed the issue.
  • We have fixed an issue that prevented garbage collection from running during in-cluster registry cleanup.
  • An issue caused the Thanos compactor to stop metrics block compaction in the object store due to a race condition in Prometheus. This led to increased storage usage in the Ceph bucket. We have fixed the issue.
  • An issue caused the pre-upgrade process to stall when deleting the rook-ceph-object-storeapplication. This issue occurred due to the CephObjectStore resource not finalizing, which prevented completion of the upgrade workflow. We fixed the issue.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2024.10.5.
Legend:
available - This Automation Suite version bundles a new version of the product. New release notes are available.
not available - This Automation Suite version bundles a previously released version of the product. No new release notes are available.
ProductProduct versionRelease statusRelease notes
Action Center2024.10.5
available
Action Center release notes
AI Center2024.10.5
available
AI Center release notes
AI Computer VisionN/A
not available
N/A
Apps2024.10.5
available
Apps release notes
Automation Hub2024.10.5
available
Automation Hub release notes
Automation Ops2024.10.5
available
Automation Ops release notes
Data Service2024.10.5
available
Data Service release notes
Document Understanding2024.10.5
available
Insights2024.10.6
available
Insights release notes
Orchestrator2024.10.8
available
Orchestrator release notes
Process Mining2024.10.5
available
Process Mining release notes
Task Mining2024.10.5
available
Task Mining release notes
Test Manager2024.10.5
available
Test Manager release notes
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.33.2+rke2r1
ArgoCDv3.0.11
gatekeeper3.20.0
rook1.17.6
ceph19.2.3
prometheus-pushgatewayv3.4.1
cert-managerv1.18.2
kube-logging/logging-operator6.0.1
kube-logging/config-reloader6.0.1
istio1.26.3
velero1.16.1
reloaderv2.2.0
Prometheusv3.5.0
Grafana12.0.2
redis-operatorv7.22.0-15
redis-clusterv7.22.0-216.focal
oauth2-proxyv7.11.0
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
