- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated Jan 8, 2025
If you experience issues with image vulnerabilities or storage consumption after performing an upgrade, you can delete the images from the old installer.
Starting with Automation Suite 2023.10.5, you can clean up the previous version images after the upgrade from the in-cluster Docker registry, using the following commands:
To delete the images that are not needed anymore after upgrade:
cd /opt/UiPathAutomationSuite/<new_version>/installer ./bin/uipathctl registry cleanup --manifest versions/docker-images.json
cd /opt/UiPathAutomationSuite/<new_version>/installer ./bin/uipathctl registry cleanup --manifest versions/docker-images.json -
To delete the on-demand bundles images, you need to specifically remove these images:
The following example shows the format of the./bin/uipathctl registry cleanup --manifest /versions/docker-images.json --images-list images-list.json
./bin/uipathctl registry cleanup --manifest /versions/docker-images.json --images-list images-list.jsonimages-list.json
file:{ "cleanup-list": [ "aicenter/python39:23.10.0-rc4", "image2", "image3" ] }
For previous Automation Suite versions, to perform this optional post-upgrade operation, take the following steps:
Update
,TAG
,USER
,PASS
,registry
, andlatest_image_json
according to the cluster configuration in the following script, then run it:#!/bin/bash ### Please change below variables as required IMG=<E.g. dataservice/dataservice-designer> TAG=<E.g. v20231116-tag> USER=<E.g. "admin"> PASS=<E.g. "password"> registry=<E.g. "registry.mycluster.com"> latest_image_json=<E.g. "/opt/UiPathAutomationSuite/UiPath_Installer/versions/docker-images.json"> #### [[ -f "${latest_image_json}" ]] || { echo "File "$latest_image_json" doesn't exist" exit 1 } cat "${latest_image_json}" | tr -d '",' | grep -w "${IMG}:${TAG}" >> /dev/null && { echo "Image ${IMG}:${TAG} is being used in cluster. Will skip the deletion." exit 0 } echo "Deleting image ${IMG}:${TAG}" cred="-u ${USER}:${PASS}" for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.layers | .[] | .digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.config.digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done
#!/bin/bash ### Please change below variables as required IMG=<E.g. dataservice/dataservice-designer> TAG=<E.g. v20231116-tag> USER=<E.g. "admin"> PASS=<E.g. "password"> registry=<E.g. "registry.mycluster.com"> latest_image_json=<E.g. "/opt/UiPathAutomationSuite/UiPath_Installer/versions/docker-images.json"> #### [[ -f "${latest_image_json}" ]] || { echo "File "$latest_image_json" doesn't exist" exit 1 } cat "${latest_image_json}" | tr -d '",' | grep -w "${IMG}:${TAG}" >> /dev/null && { echo "Image ${IMG}:${TAG} is being used in cluster. Will skip the deletion." exit 0 } echo "Deleting image ${IMG}:${TAG}" cred="-u ${USER}:${PASS}" for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.layers | .[] | .digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.config.digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done -
Run the following command in the registry pod and, then, restart the registry pod.
registry garbage-collect /etc/docker/registry/config.yaml
