Failure to add agent nodes in offline environments
Known issue where agent node addition fails in offline Automation Suite environments due to the temporary registry not being enabled.
For versions prior to Automation Suite 2024.10.4, the agent node addition process in offline environments may fail due to the temporary registry not being enabled.
Solution
To address the issue, you must manually re-enable the temporary registry to allow the agent node to successfully join the environment.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
