Automation Suite on Linux Installation Guide
Last updated Jan 8, 2025
Airflow installation fails with sqlalchemy.exc.ArgumentError: Could not parse rfc1738 URL from string ''
Possible cause
The sqlalchemy PYODBC connection strings for Process Mining are not defined correctly in the cluster_config.json.
Solution
  1. Check the processmining section in the cluster_config.json to verify if connections strings are specified properly.
  2. Check if there is sqlalchemy_pyodbc_sql_connection_str specified.
    docs image
Note:
If the sqlalchemy_pyodbc_sql_connection_str is not specified in the processmining section it should be specified in template string sql_connection_string_template_sqlalchemy_pyodbc
  • Possible cause
  • Solution
