- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Collect Document Understanding usage data with in-cluster Ceph objectstore in Automation Suite using the DU collector script.
This section explains how to collect Document Understanding (DU) usage data when using in-cluster objectstore (Ceph).
Take the following steps:
Before running the DU collector script, make sure to update the following values:
<REGISTRY>:- Use
localhost:30071for offline deployments. - Use
registry.uipath.comfor online deployments. - Use your external registry URL for private registries.
- Use
<TAG>: Openversions.jsonand locate thesf-k8-utils-rhelimage tag. Use this tag to replace<TAG>in the script.
Run the DU usage collector script after updating the values, as follows:
NAMESPACE="rook-ceph" POD_NAME="du-usage-collector" SECRET_NAME="ceph-object-store-secret" LOCAL_TAR="du-usage.tar.gz" MOUNTED_SECRET_PATH="/rook-secret" TARGET_PATH="aistorage/org-00000000-0000-0000-0000-000000000001/tenant-00000000-0000-0000-0000-000000000001" BUCKET_NAME="ai-storage" IMAGE="<REGISTRY>/uipath/sf-k8-utils-rhel:<TAG>" echo "[*] Removing pod $POD_NAME in namespace $NAMESPACE..." kubectl delete pod "$POD_NAME" -n "$NAMESPACE" --ignore-not-found=true echo "[*] Creating pod $POD_NAME in namespace $NAMESPACE..." kubectl apply -n "$NAMESPACE" -f - <<EOF apiVersion: v1 kind: Pod metadata: name: $POD_NAME namespace: $NAMESPACE spec: restartPolicy: Never containers: - name: sleep image: $IMAGE command: ["bash", "-c", "echo 'Main container started, sleeping...'; sleep 3600"] volumeMounts: - name: output mountPath: /output initContainers: - name: du-usage-collector image: $IMAGE command: ["/bin/bash", "-c"] args: - | set -euo pipefail echo "[*] Extracting Ceph secret values..." ACCESS_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_ACCESSKEY) SECRET_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_SECRETKEY) HOST=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_INTERNAL_SERVICE) PORT=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_PORT) export AWS_ACCESS_KEY_ID=\$ACCESS_KEY export AWS_SECRET_ACCESS_KEY=\$SECRET_KEY echo "[*] Syncing from s3://$BUCKET_NAME/$TARGET_PATH ..." mkdir -p /tmp/download s3cmd sync s3://$BUCKET_NAME/$TARGET_PATH/ /tmp/download/ \ --host=\$HOST:\$PORT --host-bucket= --no-ssl --no-check-certificate echo "[*] Creating archive..." mkdir -p /output tar -czf /output/du-usage.tar.gz -C /tmp/download . echo "[✔] Archive ready at /output/du-usage.tar.gz" volumeMounts: - name: rook-secret mountPath: $MOUNTED_SECRET_PATH readOnly: true - name: output mountPath: /output volumes: - name: rook-secret secret: secretName: $SECRET_NAME optional: false - name: output emptyDir: {} EOF echo "[*] Waiting for pod to be Running..." for i in {1..30}; do phase=$(kubectl get pod "$POD_NAME" -n "$NAMESPACE" -o jsonpath="{.status.phase}") if [[ "$phase" == "Running" ]]; then echo "Pod is Running." break fi echo "[$i] Still waiting..." sleep 5 done echo -e "\nArchive will be saved as: $LOCAL_TAR\n\n" echo "[*] Copying archive from pod to local..." kubectl cp "$NAMESPACE/$POD_NAME:/output/du-usage.tar.gz" "$LOCAL_TAR"NAMESPACE="rook-ceph" POD_NAME="du-usage-collector" SECRET_NAME="ceph-object-store-secret" LOCAL_TAR="du-usage.tar.gz" MOUNTED_SECRET_PATH="/rook-secret" TARGET_PATH="aistorage/org-00000000-0000-0000-0000-000000000001/tenant-00000000-0000-0000-0000-000000000001" BUCKET_NAME="ai-storage" IMAGE="<REGISTRY>/uipath/sf-k8-utils-rhel:<TAG>" echo "[*] Removing pod $POD_NAME in namespace $NAMESPACE..." kubectl delete pod "$POD_NAME" -n "$NAMESPACE" --ignore-not-found=true echo "[*] Creating pod $POD_NAME in namespace $NAMESPACE..." kubectl apply -n "$NAMESPACE" -f - <<EOF apiVersion: v1 kind: Pod metadata: name: $POD_NAME namespace: $NAMESPACE spec: restartPolicy: Never containers: - name: sleep image: $IMAGE command: ["bash", "-c", "echo 'Main container started, sleeping...'; sleep 3600"] volumeMounts: - name: output mountPath: /output initContainers: - name: du-usage-collector image: $IMAGE command: ["/bin/bash", "-c"] args: - | set -euo pipefail echo "[*] Extracting Ceph secret values..." ACCESS_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_ACCESSKEY) SECRET_KEY=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_SECRETKEY) HOST=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_INTERNAL_SERVICE) PORT=\$(cat $MOUNTED_SECRET_PATH/OBJECT_STORAGE_PORT) export AWS_ACCESS_KEY_ID=\$ACCESS_KEY export AWS_SECRET_ACCESS_KEY=\$SECRET_KEY echo "[*] Syncing from s3://$BUCKET_NAME/$TARGET_PATH ..." mkdir -p /tmp/download s3cmd sync s3://$BUCKET_NAME/$TARGET_PATH/ /tmp/download/ \ --host=\$HOST:\$PORT --host-bucket= --no-ssl --no-check-certificate echo "[*] Creating archive..." mkdir -p /output tar -czf /output/du-usage.tar.gz -C /tmp/download . echo "[✔] Archive ready at /output/du-usage.tar.gz" volumeMounts: - name: rook-secret mountPath: $MOUNTED_SECRET_PATH readOnly: true - name: output mountPath: /output volumes: - name: rook-secret secret: secretName: $SECRET_NAME optional: false - name: output emptyDir: {} EOF echo "[*] Waiting for pod to be Running..." for i in {1..30}; do phase=$(kubectl get pod "$POD_NAME" -n "$NAMESPACE" -o jsonpath="{.status.phase}") if [[ "$phase" == "Running" ]]; then echo "Pod is Running." break fi echo "[$i] Still waiting..." sleep 5 done echo -e "\nArchive will be saved as: $LOCAL_TAR\n\n" echo "[*] Copying archive from pod to local..." kubectl cp "$NAMESPACE/$POD_NAME:/output/du-usage.tar.gz" "$LOCAL_TAR" -
After retrieving the archive, delete the pod:
kubectl delete pod "$POD_NAME" -n "$NAMESPACE"kubectl delete pod "$POD_NAME" -n "$NAMESPACE"
The du-usage.tar.gz file contains the DU usage data.
