- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring log rules
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
To migrate from standalone Insights to Automation Suite, you must remap of the organization IDs in the following tables:
[Id] [int] NOT NULL,
[Key] [nvarchar](128) NOT NULL,
[Name] [nvarchar](128) NOT NULL,
[IsActive] [bit] NOT NULL,
[IsDeleted] [bit] NOT NULL,
[OrganizationId] [nvarchar](128) NULL,
CONSTRAINT [PK_dbo.Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsintegrations].[TenantServiceIntegrations](
[Id] [uniqueidentifier] NOT NULL,
[TenantId] [uniqueidentifier] NOT NULL,
[OrganizationId] [uniqueidentifier] NOT NULL,
[ServiceName] [int] NOT NULL,
[Status] [int] NOT NULL,
[CreationTime] [datetime2](7) NOT NULL,
[LastUpdatetime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantServiceIntegrations] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[GroupRoles](
[GroupId] [uniqueidentifier] NOT NULL,
[RoleId] [uniqueidentifier] NOT NULL,
CONSTRAINT [PK_GroupRoles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Groups](
[Name] [nvarchar](max) NULL,
[Email] [nvarchar](max) NULL,
CONSTRAINT [PK_Groups] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Roles](
[TenantId] [uniqueidentifier] NULL,
[Resource] [nvarchar](max) NULL,
CONSTRAINT [PK_Roles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[TenantGroups](
[TimeProcessed] [datetime2](7) NULL,
[LastUpdateTime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantGroup] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Tenants](
CONSTRAINT [PK_Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Users](
[IsDeleted] [bit] NULL,
CONSTRAINT [PK_Users] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsprovisioning].[TenantInstances](
[ServiceType] [nvarchar](max) NULL,
[State] [int] NOT NULL,
[TenantName] [nvarchar](max) NULL,
CONSTRAINT [PK_TenantInstances] PRIMARY KEY CLUSTERED
CREATE TABLE [read].[HASHKEYS](
[hashkey] [bigint] NOT NULL,
[tenantkey] [nvarchar](128) NOT NULL,
[tenantname] [nvarchar](256) NULL,
[organizationid] [nvarchar](128) NULL,
[status] [int] NULL
[status] [int] NULL
[dbo].[Tenants]
[read].[HASHKEYS]
[dbo].[Tenants]
[read].[HASHKEYS]
Tip:
This is an example on how to update the tables:
--- Script to replace MSI organization ID with AS organization ID.
--- Please update the following DECLARE statements with your corresponding MSI org ID and AS org ID before executing this script.
DECLARE @msi_organization_id NVARCHAR(500) = UPPER('687db434-ce5c-4058-bc0b-3ed3fa23882b');
DECLARE @as_organization_id NVARCHAR(500) = UPPER('AA259F1A-5828-4608-AF71-27177A7831B8');
DECLARE @msi_resource NVARCHAR(500) = LOWER('insights/687db434-ce5c-4058-bc0b-3ed3fa23882b/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
DECLARE @as_resource NVARCHAR(500) = LOWER('insights/aa259f1a-5828-4608-af71-27177a7831b8/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
SELECT *
FROM [dbo].[Tenants];
UPDATE [dbo].[Tenants]
SET OrganizationId = LOWER(@as_organization_id)
WHERE OrganizationId = LOWER(@msi_organization_id);
SELECT *
FROM [insightsintegrations].[TenantServiceIntegrations];
UPDATE [insightsintegrations].[TenantServiceIntegrations]
SET OrganizationId = @as_organization_id
WHERE OrganizationId = @msi_organization_id;
ALTER TABLE [insightspermissions].[GroupRoles]
NOCHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
SELECT *
FROM [insightspermissions].[GroupRoles];
UPDATE [insightspermissions].[GroupRoles]
ALTER TABLE [insightspermissions].[TenantGroups]
NOCHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT *
FROM [insightspermissions].[TenantGroups];
UPDATE [insightspermissions].[TenantGroups]
SELECT *
FROM [insightspermissions].[Groups];
UPDATE [insightspermissions].[Groups]
SELECT *
FROM [insightspermissions].[Roles];
UPDATE [insightspermissions].[Roles]
SET Resource = @as_resource
WHERE Resource = @msi_resource;
SELECT *
FROM [insightspermissions].[Tenants];
UPDATE [insightspermissions].[Tenants]
SELECT *
FROM [insightspermissions].[Users];
UPDATE [insightspermissions].[Users]
SELECT *
FROM [insightsprovisioning].[TenantInstances];
UPDATE [insightsprovisioning].[TenantInstances]
SELECT *
FROM [read].[HASHKEYS];
UPDATE [read].[HASHKEYS]
SELECT *
SELECT *
SELECT *
SELECT *
SELECT *
SELECT *
SELECT *
SELECT *
SELECT *
SELECT *
