- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Update the registry credentials in cluster_config.json and apply the changes in Automation Suite.
To update the registry credentials, take the following steps:
Update the registry credentials section in the
cluster_config.jsonconfiguration file:"registries": { "docker": { "url": "yourContainerRegistryUrl", "username": "username", "password": "<your-password>" , "pull_secret_value": "new_pull_secret_value" }, "helm": { "url": "yourContainerRegistryUrl", "username": "username", "password": "<your-password>" } }"registries": { "docker": { "url": "yourContainerRegistryUrl", "username": "username", "password": "<your-password>" , "pull_secret_value": "new_pull_secret_value" }, "helm": { "url": "yourContainerRegistryUrl", "username": "username", "password": "<your-password>" } }To generate the value for
pull_secret_value, refer to the How to section. -
Re-run the Automation Suite infrastructure installation as follows:
- Re-install the infrastructure on the first server machine. For details, refer to Step 2: Installing the infrastructure on the first server machine.
- Re-install the infrastructure on the other server machines. For details, refer to Step 3: Installing the infrastructure on the other server machines.
- Re-install the infrastructure on the agent nodes. For details, refer to Step 4: Installing the infrastructure on all the agent machines.
Depending on the node type, restart the
rke2-serverorrke2-agentservices on all nodes, by running the following commands:-
On server nodes, to restart the
rke2-serverservice, run the following command:systemctl restart rke2-serversystemctl restart rke2-server -
On agent nodes, to restart the
rke2-agentservice, run the following command:systemctl restart rke2-agentsystemctl restart rke2-agent
Delete the existing
uipathpullsecretsecret in all namespaces, by running the following commands:kubectl get secrets --all-namespaces | grep uipathpullsecret | awk '{print $1 " " $2}' | while read namespace secret; do kubectl delete secret "$secret" -n "$namespace" ; done ;kubectl get secrets --all-namespaces | grep uipathpullsecret | awk '{print $1 " " $2}' | while read namespace secret; do kubectl delete secret "$secret" -n "$namespace" ; done ; -
Re-run the fabric and services installation. For details, refer to Step 6: Completing the installation.
