Automation Suite on Linux Installation Guide
Last updated Jan 22, 2025
RKE2 server fails to start
The server fails to start. There are a few different reasons for RKE2 not starting properly, which are usually found in the logs.
Solution
Check the logs using the following commands:
journalctl -u rke2-serverjournalctl -u rke2-server
Possible reasons (based on logs): too many learner members in cluster
Too many etcd servers are added to the cluster, and there are two learner nodes trying to be promoted. More information here: Runtime reconfiguration.
Perform the following:
  1. Under normal circumstances, the node should become a full member if enough time is allowed.
  2. An uninstall-reinstall cycle can be attempted.
Alternatively, this could be caused by a networking problem. Ensure you have configured the machine to enable the necessary ports.
  • Description
  • Solution
