Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
    • 2024.10.7
    • 2024.10.8
    • 2024.10.10
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
2024.10.4
2024.10.4 release notes for Automation Suite on Linux.
Release date: March 26, 2026
Support for new RHEL version​
We have expanded our OS support to include RHEL 9.7. For details on the supported RHEL versions, refer to RHEL compatibility matrix.
Release date: June 26, 2025
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Release date: September 24, 2025
Changes to the patching procedure​
The procedure for applying patches now includes an additional step that requires you to download and use the corresponding uipathctl patch version before proceeding with the patch.
For more details, refer to Applying a patch.
Deprecation of UiPath Backup based on NFS server​
Starting with Automation Suite 2025.10, NFS server-based backups will not be supported if you are using an external objectstore. Your backups will be stored directly in the external objectstore. If you are upgrading to 2025.10, you are encouraged to switch to the external objectstore for backups.
Learn more about Configuring the external objectstore or reach out to support.
Bug fixes​
  • Erratum - added July 17, 2025: We have fixed an issue where uploading large Document Understanding bundles caused nodes to go out of memory due to parallel loading of large-sized image layers into memory.
  • An issue was causing the Task Mining service to fail to initialize in certain Kerberos environments. This occurred due to missing configuration or parameters related to keytab secrets and app settings. We have fixed the issue.
  • An issue was causing the addition process of agent nodes to fail in offline environments. We have fixed the issue.
  • We have fixed an issue causing frequent restarts of deployments in the uipath namespace during offline installations due to inconsistent istio-ingressgateway-certs secrets across namespaces.
  • We have fixed an issue causing Automation Suite installations to fail due to Certificate Authority (CA) certificates not being recognized. The issue occurred when the CertificatePolicies section included policy OID values exceeding 4 bytes.
  • We have fixed an issue causing the custom changes made to the RKE2 configuration file (/etc/rancher/rke2/config.yaml) to be overwritten during upgrades. Now, the custom configurations are preserved.
  • We have fixed an issue where the Process Mining portal failed to load the process apps.
  • Log forwarding did not work in proxy setups because the proxy environment variables were not set in the logging pods. We have fixed the issue.
  • Licensing SQL connection errors occurred when the Data Source property specified both a named instance and a port. We have fixed the issue.
  • We have fixed an issue that caused service disruptions due to automatic secret rotation, making services temporarily inaccessible.
Known issues​
Kerberos KDC discovery fails in Active/Active deployments due to truncated DNS SRV responses​
Erratum - added September 10, 2026: In Automation Suite Active/Active deployments on Linux (RKE2), Kerberos KDC discovery can fail during installation or upgrade, resulting in Integrated Authentication and LDAP errors. The issue occurs because the Kubernetes DNS Service exposes DNS resolution over UDP/53 only. When a Kerberos SRV lookup, such as _kerberos._tcp or _kerberos._udp, returns a response too large for UDP, the DNS client retries over TCP/53. Since the Kubernetes DNS Service doesn't expose TCP/53, the retry fails.
To address the issue, enable TCP/53 on the Kubernetes DNS Service:
  1. Edit the rke2-coredns Helm chart configuration:
    kubectl -n kube-system edit helmchartconfig rke2-coredns
  2. Under zone in spec.valuesContent, add use_tcp: true:
    servers:
    - zones:
      - zone: .
        use_tcp: true
      port: 53
    servers:
    - zones:
      - zone: .
        use_tcp: true
      port: 53
We fixed the issue in Automation Suite 2024.10.10.
Monitoring configuration updates do not take effect​
Erratum - added July 2, 2026: An issue prevents the monitoring section parameters in cluster_config.json from being applied to the monitoring stack.
This issue is fixed in Automation Suite 2024.10.9.
Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled​
Erratum - added July 2, 2026: An issue causes the prerequisite checks command to incorrectly fail when Document Understanding modern projects is enabled and AI Center is disabled.
To address the issue, refer to Troubleshooting.
Custom platform database name not supported when installing Process Mining​
Erratum - added March 26, 2026: When Process Mining is enabled, using a custom platform database name causes the OMS backfill job to fail.
As a workaround, use AutomationSuite_Platform as the platform database name when installing Process Mining.
Redis telemetry job pods failing in airgapped environments​
Erratum - added March 26, 2026: Redis telemetry is enabled by default but the required image is not included in the offline bundle, causing ImagePullBackOff errors in airgapped environments. You can either ignore the errors or delete the Redis telemetry cronjob.
We fixed the issue in Automation Suite 2024.10.8.
Prerequisite check incorrectly validates monitoring and logging components​
Erratum - added March 26, 2026: The prerequisite check incorrectly validates monitoring and logging components. Since these components are installed after the prerequisite phase, this validation is not necessary.
Insights real-time monitoring not working on the secondary cluster in Active/Active deployments​
Erratum - added March 26, 2026: In Active/Active deployments with Insights real-time monitoring enabled, Orchestrator and platform services on the secondary cluster do not push real-time monitoring data due to configuration issues with call redirection from the secondary cluster to the primary cluster.
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
AI Center in-cluster proxy connectivity issue​
Erratum - added December 19, 2025: An issue prevents AI Center pods from connecting to the in-cluster object store in proxy-enabled environments. This occurs due to unsupported CIDR notations and FQDN regex patterns in the no_proxy configuration.
To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2024.10.7.
Prerequisite checks fail when Process Mining is enabled​
Erratum - added December 19, 2025: An issue causes the prerequisite checks to fail when Process Mining is enabled. The issue occurs due to the checks still requiring cert-manager, although cert-manager is no longer needed for Process Mining starting with Automation Suite 2024.10.3.
The failure message is a false positive and can be safely ignored.
Pre-upgrade command fails with proxy and external objectstore​
Erratum - added December 19, 2025: An issue prevents the uipathctl cluster pre-upgrade command from completing successfully in environments configured with a proxy and external objectstore. The issue occurs due to an error during the Insights volume migration process.
Upgrade failure during posthook import in chained upgrades​
Erratum - added December 19, 2025: An issue causes the upgrade to fail during the execution of the uipathctl rke2 upgrade command in chained upgrade scenarios. This issue occurs due to the posthook secret and configmap import operation not being idempotent, which leads to conflicts with existing Kubernetes objects.
Kerberos keytab rotation does not trigger token regeneration​
Erratum - added September 24, 2025: An issue causes Kerberos keytab rotation to not immediately regenerate authentication tokens, which may lead to temporary connectivity disruptions between services and the database.
To address the issue, you must manually trigger the Kerberos ticket renewal cronjob by running the following command:
kubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipath
We fixed the issue in Automation Suite 2024.10.5.
Registry certificates not fully updated in offline scenarios​
Erratum - added September 24, 2025: An issue causes the uipathctl config tls-certificates command to update only the internal certificate, while missing the certificate required by Argo CD to trust the in-cluster registry in offline scenarios.
To address the issue, you must run the following command to explicitly update the ArgoCD registry certificate in internal–external registry scenarios:
./bin/uipathctl config argocd ca-certificates update --cacert [PATH]
GPU enablement fails with external registries containing project names​
Erratum - added September 24, 2025: An issue prevents GPU enablement after adding a GPU node when using external registries with project names (such as Harbor). The required pods do not start and display an ImagePullBackoff error.
If you are using an external registry with a project name, update the NVIDIA device plugin daemonset with the following command:
# Replace REGISTRY_WITH_PROJECT_NAME with the correct value (Eg. my.registry.io:443/myproject)
# Replcae TAG with the correct value. You can get this from the <installer_directory>/versions/docker-images.json file (Eg. v0.17.1)
kubectl set image daemonset/nvidia-device-plugin-daemonset \
  -n kube-system \
  nvidia-device-plugin-ctr=<REGISTRY_WITH_PROJECT_NAME>/k8s-device-plugin:<TAG>
  -n kube-system \
Orchestrator does not start when using user-assigned managed identity​
Erratum - added September 24, 2025: An issue prevents the storage.useClientID parameter from being set when you select a user-assigned managed identity for object storage. As a result, Orchestrator cannot start in environments where access is restricted to user-assigned managed identities.
To address the issue, you must manually set the parameter in ArgoCD, as follows:
  1. In the ArgoCD Orchestrator application, go to Details > Parameters.
  2. In the values text box, set storage.isExternal : true and save.
Temporary registry installation timeout​
Erratum - added September 24, 2025: An issue causes the temporary registry installation to fail with a timeout error when connecting to registry-1.docker.io. To address the issue, refer to the Troubleshooting section.
Thanos compactor stops on corrupted blocks​
Erratum - added September 24, 2025: An issue causes the Thanos compactor to stop compacting metrics when it encounters corrupted blocks in the object store. This prevents compaction and leads to increased storage usage.
Upgrade fails during rook-ceph app deletion​
Erratum - added September 24, 2025: An issue causes the upgrade to fail at the pre-upgrade stage and get stuck while deleting the rook-ceph ArgoCD application. This issue occurs when upgrading from Automation Suite 2023.10.10 to version 2024.10.4.
Garbage collection fails during registry cleanup​
Erratum - added September 24, 2025: An issue prevents garbage collection from executing correctly during in-cluster registry cleanup. This may result in unused images not being cleaned up as expected.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2024.10.4Automation Ops 2024.10.4AI Center 2024.10.4Action Center 2024.10.4
Task Mining 2024.10.4AI Computer Vision 2024.10.4Insights 2024.10.4Apps 2024.10.4
Process Mining 2024.10.4Document Understanding AI Center-based projects 2024.10.4
Document Understanding modern projects 2024.10.4
Orchestrator 2024.10.6
Test Manager 2024.10.4
Data Service 2024.10.4
Internal third-party component versions​
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.32.3+rke2r1
ArgoCDv3.0.0
gatekeeper3.19.1
rook1.17.1
ceph19.2.2
prometheus-pushgatewayv3.1.3
cert-managerv1.17.2
kube-logging/logging-operator5.3.0
kube-logging/config-reloader5.3.0
istio1.25.2
velero1.16.0
reloaderv2.1.3
Prometheusv3.3.0
Grafana11.6.1
redis-operatorv7.22.0-7
redis-clusterv7.22.0-28.focal
oauth2-proxyv7.9.0
Migration tool version​
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Stay updated
