Last updated Apr 15, 2026
AI Center-specific configuration
This section only applies to S3 endpoints (not needed for Azure Storage).
For AI Center to function properly, you must configure the aicenter.external_object_storage.port and aicenter.external_object_storage.fqdn parameters in the cluster_config.json file.
Note:
You must configure the parameters in the aicenter section of the cluster_config.json file even if you have configured the external_object_storage section of the file.
The following sample shows a valid cluster_config.json configuration for AI Center:
"aicenter": {
  "external_object_storage" {
    "port": 443,
    "fqdn": "s3.us-west-2.amazonaws.com"
"external_object_storage": {
  "enabled": true,
  "create_bucket": false,
  "storage_type": "s3",
  "region": "us-west-2",
  "use_instance_profile": true
"aicenter": {
    "port": 443,
  "enabled": true,
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
