- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Antivirus causes installation and operation issues
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Network requirements
Network requirements and constraints for Automation Suite, including IPv6 limitations, firewalld support, and IP table rules.
Automation Suite does not support the IPv6 internet protocol.
Using a firewall
We do not support firewalld. The Automation Suite installer automatically disables firewalld during installation; make sure it remains in a disabled state post-installation as well.
Automation Suite sets up default IP table rules on the host machines for necessary inter-node communication. We do not support custom IP table rules, such as those configured via firewalld, as they might conflict with IP table rules configured by Automation Suite. You can, however, apply extra firewall rules at the network level.
Changes to IP tables are not recommended or supported.
We recommend enabling firewall applications at the network gateway, but not between clusters.
Allowing traffic in an online environment
This page lists the domains used by the various UiPath® products, components, and integrations in an online deployment. You must allow traffic to and from these domains, otherwise Automation Suite may malfunction.
Add to your allow list those endpoints and ports for the UiPath® products and services you use. For example, if you do not have AI Center, there is no need to add its required domains to your allow list.
General requirements
To ensure cluster stability, your environment must meet the following requirements:
- Round Trip Time (RTT) between the nodes must be minimal (<10 ms RTT);
- High Availability requirements must be met.
Installation
For downloading the required installer files and configuration scripts:
https://download.uipath.com
For downloading container images and metadata:
https://registry-data.uipath.com -
https://registry.uipath.comThe previous URLs are required during installation, for adding new nodes to an existing cluster, for upgrading to a newer version, and for application sync using ArogCD. These URLs may also be needed during runtime so that Kubernetes can pull the image.
For using supportability tools, such as the support bundle generation and diagnostic tools:
https://sfbrprddeploywe.azurecr.iohttps://sfbrprddeploywe.westeurope.data.azurecr.io
For the installation of Kubernetes or RKE2:
https://rpm.rancher.io
For sending business telemetry to UiPath®:
https://dc.services.visualstudio.com
This is only required if you opt in to send telemetry data to UiPath®.
Shared Platform Capabilities
Automation Suite portal
For the Azure Active Directory integration:
https://login.microsoftonline.com/*
(Optional) For application insights:
https://dc.services.visualstudio.com/*
Identity
https://login.microsoftonline.com/*https://graph.microsoft.com/*
For the SQL connection: the connection you use, possibly through a pipeline
For the Redis connection: the port number and password that are generated during Redis deployment
For the Active Directory integration:
- Kerberos: port
88 - LDAP endpoints: port
389 - DNS for DC discovery: port
53
- Kerberos: port
For SAML authentication: SAML endpoints, as configured for Automation Suite
For system email notifications: SMTP server and port, as configured for Automation Suite
For certificate validation on connection, if CRLs need to be downloaded: the endpoint determined by the certificate
Webhooks
- For the SQL connection: the connection you use, possibly through a pipeline
- HTTP(S) Webhook endpoints, as defined by users in the Orchestrator Webhook definition
Organization management
- For the Ceph integration: the connection is generated during infrastructure setup
Audit
Licensing
For online license activation, update, and other online license operations:
https://activate.uipath.com/
Orchestrator
Automation Suite serves the host Libraries feed from inside Orchestrator, using the activity packages seeded at installation time, and needs no outbound access for it. If you point the Libraries feed at the official UiPath® feed instead, allow:
https://pkgs.uipath.com/official/index.jsonhttps://pkgs.dev.azure.com/uipath/Public.Feeds/_packaging/UiPath-Official/nuget/v3/index.json
pkgs.uipath.comis the new address of the official feed, and it replaces the Azure DevOps-hosted address. Allow both while your deployment transitions between them. For the announced feed migration dates, see the deprecation timeline.
Test Manager
- HTTP(S) calls via the Webhook connector
- HTTP(S) calls to Xray for Jira (on-premises or cloud), to ServiceNow, and to AzureDevOps
AI Center
The OOB models and metadata are fetched from our GitHub repository, and the models themselves are downloaded from our storage account. The following URLs cannot be blocked as the OOB scheduler continues to run, and the last three URLs as they are needed at runtime. Therefore, make sure that you have access to the following:
The following are needed in order for the OOB metadata to fetch new models being added:
https://github.comhttps://raw.github.comhttps://raw.githubusercontent.comhttps://api.github.com
Needed to clone the new models downloaded:
https://uipath.blob.core.windows.net
The following are needed at runtime for skill deployment and training pipeline for downloading dependencies:
The Python Package Index:
http://pypi.python.org/http://pypi.org/
Any Python PIP hosted public domains, based on your model package and required Python libraries in
requirements.txt
https://du-metering.uipath.comNote:This URL is needed only when AI Center is connected to an external Orchestrator.
https://du.uipath.com
For OCR:
The UiPathDocumentOCR endpoint applicable for your region
Microsoft OCR (optional): The endpoint applicable for your region
Google OCR (optional):
https://vision.googleapis.com/v1/images:annotate
For data extraction: the FormExtractor endpoint applicable for your region
Task Mining
- To download desktop clients:
https://download.uipath.com/TaskMining/sf/task-mining-setup.exe(EXE) andhttps://download.uipath.com/TaskMining/sf/task-mining-setup.msi(MSI) - For the SQL connection: the connection you use, possibly through a pipeline
- For system email notifications: SMTP server and port, as configured for Automation Suite
- For the Redis connection: the port number and password that are generated during Redis deployment
- For the RabbitMQ connection: the connection is generated during infrastructure setup
Insights
Data Service
Runtime URL dependencies
https://activate.uipath.com -
smtp.sendgrid.net(or whichever SMTP server is configured)- Any port-level blocks need to be accounted for.
- Any TLS or SSL certificates associated with the SMTP server should be verifiable without the need for a CRL fetch outside your offline environment.
https://dc.services.visualstudio.com/v2/track
Azure dependencies
If you use Azure infrastructure, you must allow the RHEL yum mirrors for Azure listed in this section.
These URLs are strictly applicable for Azure. If you use a different cloud services provider (CSP), the URLs are different.
http://rhui-1.microsoft.com -
http://rhui-2.microsoft.com -
http://rhui-3.microsoft.com -
Documentation
For your users to be able to access the official UiPath® documentation for Automation Suite and the bundled products, you must also allow documentation-specific URLs. For the full list, refer to UiPath® Documentation Website URLs.
