Compatibility matrix
When migrating from a standalone product to Automation Suite, you must make sure the versions of the standalone product, UiPath.OrganizationMigrationApp, and Automation Suite are compatible.
The following table describes the version compatibility required to perform a migration to Automation Suite:
Standalone product version UiPath.OrganizationMigrationApp version Automation Suite version
OrchestratorInsights
2022.10.152022.10.122022.10.142022.10.14
2022.10.132022.10.112022.10.142022.10.13
2022.10.122022.10.102022.10.122022.10.12
2022.10.112022.10.92022.10.112022.10.11
2022.10.10N/A2022.10.102022.10.10
2022.10.8N/A2022.10.82022.10.9
2022.10.7N/A2022.10.72022.10.8
2022.10.6N/A2022.10.62022.10.7
2022.10.5N/A2022.10.52022.10.6
Note:
How to read the table
  • As an example, to migrate standalone Orchestrator 2022.10.5, you must use UiPath.OrganizationMigrationApp 2022.10.5 and make sure that you installed Automation Suite 2022.10.6.
  • For information on updates to the UiPath.OrganizationMigrationApp and the migration workflows, see the release notes for your targeted Automation Suite version by clicking the corresponding link in the Automation Suite version column. If there is no entry dedicated to the UiPath.OrganizationMigrationApp in the release notes, this means that we made only minor improvements to the tool.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
