- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Manual: Installing Automation Suite
- Disaster recovery - Installing the secondary cluster
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Exploring Logs
The following table lists the steps you must perform for Automation Suite installation:
Steps |
Single-node installation |
Multi-node installation |
Lite mode |
Step 1: Accepting the license agreement |
Step 2: Installing the Infrastructure on the first server machine |
Step 3: Installing the infrastructure on the other server machines |
Step 4: Installing the infrastructure on all the agent machines |
Step 5: Hydrating the in-cluster registry for offline installations |
Step 6: Completing the installation |
Before running the installation, make sure to read the license agreement.
To accept the license agreement, choose one of the following methods:
- Option 1 (Environment variable) - Set the
LICENSE_AGREEMENT
environment variable toaccept
by running the following command:export LICENSE_AGREEMENT=accept
- Option 2 (Inline parameter) - Append
--accept-license-agreement
to every execution ofuipathctl
To install the infrastructure on the first server machine, navigate to the installer folder and run the following command:
cd /opt/UiPathAutomationSuite/<version>/installer
./bin/uipathctl rke2 install -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k --accept-license-agreement
The
-k
parameter installs the infrastructure on the first server machine. -
Once the infrastructure is installed, the server machine becomes a node in the Automation Suite cluster.
To expand the Automation Suite cluster, install the infrastructure on the additional server machines.
To do that, run the following command on all the additional server machines:
./bin/uipathctl rke2 install -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k -j server --accept-license-agreement
-j server
parameter adds the machines as server nodes to the existing Automation Suite cluster. The fixed_rke_address
flag in the cluster_config.json
file connects the exiting Automation Suite cluster.
If you have additional agent machines, you must install the infrastructure on those machines and add them as agent nodes to the Automation Suite cluster.
To to that, run the following command on all the agents machines:
./bin/uipathctl rke2 -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k -j agent --accept-license-agreement
-j
server parameter adds the machines as server nodes to the existing Automation Suite cluster. The fixed_rke_address
This step is required only if you use in-cluster registry for offline installations.
To seed the in-cluster registry from the temporary registry, run the following command:
./bin/uipathctl rke2 registry hydrate-registry /opt/UiPathAutomationSuite/cluster_config.json
At this point, all the nodes should be interconnected to establish the infrastructure for installing Automation Suite. To verify if all nodes are available on the first server node and to complete the installation, run the following command:
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml
export PATH=$PATH:/var/lib/rancher/rke2/bin
kubectl get nodes
kubectl get nodes
The output of the aforementioned command should look similar to the one shown in the following image. Note that the total number of nodes must match the sum of server and agent nodes.
After verifying the infrastructure, install the shared components and the services by running the following command:
./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions ./versions/helm-charts.json
- Step 1: Accepting the license agreement
- Step 2: Installing the infrastructure on the first server machine
- Step 3: Installing the infrastructure on the other server machines
- Step 4: Installing the infrastructure on all the agent machines
- Step 5: Hydrating the in-cluster registry for offline installations
- Step 6: Completing the installation
