Last updated Dec 23, 2025
Updating credentials
Guidelines
To update credentials for the different Automation Suite components, take the following steps:
  1. Generate the cluster_config.json file.
  2. Provide the new credentials for the given components in the cluster_config.json as described in each component section.
  3. Run the the installer as described in each component section.
  • Guidelines
© 2005-2026 UiPath. All rights reserved.
