Last updated Nov 6, 2025
Unhealthy Insights component causes the migration to fail
During Longhorn migration, the Insights component may take longer to complete than expected, resulting in migration failure with the "Migration failed to complete in 4500 seconds" error.
Solution 1
Make sure the Insights component is healthy in ArgoCD, then rerun the following migration command:
./configureUiPathAS.sh longhorn migrate --excluded registry./configureUiPathAS.sh longhorn migrate --excluded registry
Note: It may take up to 10 minutes to get to the healthy status.
If the Insights component does not turn healthy, rerun the previous command, then select Yes when prompted to rollback the migration. Reach out to support to troubleshoot the Insights component.
  • Description
  • Solution 1
