- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated Jan 8, 2025
Ocassionally, after a side-by-side upgrade, the Rook-ceph application goes into a "sync failed" state in the ArgoCD portal. This is due to an upstream Ceph issue.
To identify the reason of the degraded state, run the following command:
kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph -s
If you receive an output resembling the following example, the issue is related to the Rook-Ceph health:
cluster:
health: HEALTH_ERR
Module 'devicehealth' has failed: disk I/O error
services:
mon: 3 daemons, quorum a,b,c (age 11h)
mgr: b(active, since 37h), standbys: a
osd: 3 osds: 3 up (since 37h), 3 in (since 37h)
rgw: 2 daemons active (2 hosts, 1 zones)
data:
pools: 8 pools, 225 pgs
objects: 53.57k objects, 26 GiB
usage: 80 GiB used, 688 GiB / 768 GiB avail
pgs: 225 active+clean
io:
client: 561 KiB/s rd, 61 KiB/s wr, 316 op/s rd, 123 op/s wr
cluster:
health: HEALTH_ERR
services:
data:
io:
To fix the issue, take the following steps:
In the output snippet, identify the manager
mgr
service with an active state. In the example provided,mgr: b
is marked as active. -
To identify the exact pod name, run the following command:
kubectl -n rook-ceph get pods | grep "rook-ceph-mgr-<active-manager-name>"
kubectl -n rook-ceph get pods | grep "rook-ceph-mgr-<active-manager-name>"The command should return an output similar to the following example, whererook-ceph-mgr-b-6d7bdb4b54-zz47v
is the manager pod name:rook-ceph-mgr-b-6d7bdb4b54-zz47v 0/1 Init:0/1 0 3h55m
rook-ceph-mgr-b-6d7bdb4b54-zz47v 0/1 Init:0/1 0 3h55m -
Delete the active manager by running the following command:
kubectl -n rook-ceph delete pod <active-manager-pod-name> // for example: kubectl -n rook-ceph delete pod rook-ceph-mgr-b-6d7bdb4b54-zz47v
Deleting the active manager forces it to restart, turning the Ceph cluster state to healthy.
