- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Configuring log rules
Robot logs capture diagnostic and execution logs. You can configure the conditions for which Robot logs are ingested by Insights. For example, you only want to capture logs for Processes that include a specific name.
For more information, check Robot logs.
Configure Log Rules
You can configure the Orchestrator settings in the nlog.custom.config file. To modify the settings, take the following steps:
Place the new log rules inside the
nlog.custom.configfile. Check the following details for an example:{ "10_Robot_Insights": { "logger": "Robot.*", "ruleName": "insightsRobotLogsRule", "minLevel": "Info", "writeTo": "insightsRobotLogs", "enabled": false, "final": false, "filters": { "defaultAction": "Ignore", "conditions": [ { "condition": "level >= LogLevel.Error or ends-with('${message}', ' execution ended')", "action": "Log" } ] } } }{ "10_Robot_Insights": { "logger": "Robot.*", "ruleName": "insightsRobotLogsRule", "minLevel": "Info", "writeTo": "insightsRobotLogs", "enabled": false, "final": false, "filters": { "defaultAction": "Ignore", "conditions": [ { "condition": "level >= LogLevel.Error or ends-with('${message}', ' execution ended')", "action": "Log" } ] } } } -
Use the Orchestrator Configurator Tool to update the configuration. Use the following command to merge the keys from the custom
nlog.custom.configfile with the settings already available in theorchestrator-customconfigconfiguration map../orchestrator-configurator.sh -l nlog.custom.config./orchestrator-configurator.sh -l nlog.custom.configThis command does not remove any existing settings.
Log Rules Example
In the following example, we are only sending logs that exceed a certain level or contain the message that the execution has ended:
"minLevel": "Info",
"enabled": false,
"final": false,
"filters": {
"conditions": [
"action": "Log"
"minLevel": "Info",
"enabled": false,
"final": false,
"filters": {
"conditions": [
"action": "Log"
