- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Enabling SSO for ArgoCD
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
You must generate the RBAC file and the Dex configuration file before enabling SSO for ArgoCD.
The RBAC file
The RBAC file contains access rules.
For details on the built-in role definitions, see the ArgoCD documentation.
For details on the ArgoCD account types and their permissions, see Managing the cluster in ArgoCD.
We recommend using these roles when defining your groups, but you can create your own set of permissions.
Configuring the RBAC file
Example:
If your LDAP group for ArgoCD administrators is Administrators and the LDAP group for ArgoCD read-only users is Readers, the RBAC file should be similar to the one in the following example:
p, role:uipath-sync, applications, get, */*, allow
p, role:uipath-sync, applications, sync, */*, allow
g, argocdro, role:uipath-sync
g, Readers, role:uipath-sync
g, Administrators, role:adminp, role:uipath-sync, applications, get, */*, allow
g, Administrators, role:adminFor more advanced use cases, the following example shows the default RBAC file:
# Built-in policy which defines two roles: role:readonly and role:admin,
# and additionally assigns the admin user to the role:admin role.
# There are two policy formats:
# 1. Applications, logs, and exec (which belong to a project):
# p, <user/group>, <resource>, <action>, <project>/<object>
# 2. All other resources:
# p, <user/group>, <resource>, <action>, <object>
p, role:readonly, applications, get, */*, allow
p, role:readonly, certificates, get, *, allow
p, role:readonly, clusters, get, *, allow
p, role:readonly, repositories, get, *, allow
p, role:readonly, projects, get, *, allow
p, role:readonly, accounts, get, *, allow
p, role:readonly, gpgkeys, get, *, allow
p, role:readonly, logs, get, */*, allow
p, role:admin, applications, create, */*, allow
p, role:admin, applications, update, */*, allow
p, role:admin, applications, delete, */*, allow
p, role:admin, applications, sync, */*, allow
p, role:admin, applications, override, */*, allow
p, role:admin, applications, action/*, */*, allow
p, role:admin, applicationsets, get, */*, allow
p, role:admin, applicationsets, create, */*, allow
p, role:admin, applicationsets, update, */*, allow
p, role:admin, applicationsets, delete, */*, allow
p, role:admin, certificates, create, *, allow
p, role:admin, certificates, update, *, allow
p, role:admin, certificates, delete, *, allow
p, role:admin, clusters, create, *, allow
p, role:admin, clusters, update, *, allow
p, role:admin, clusters, delete, *, allow
p, role:admin, repositories, create, *, allow
p, role:admin, repositories, update, *, allow
p, role:admin, repositories, delete, *, allow
p, role:admin, projects, create, *, allow
p, role:admin, projects, update, *, allow
p, role:admin, projects, delete, *, allow
p, role:admin, accounts, update, *, allow
p, role:admin, gpgkeys, create, *, allow
p, role:admin, gpgkeys, delete, *, allow
p, role:admin, exec, create, */*, allow
g, role:admin, role:readonly
g, admin, role:admin# Built-in policy which defines two roles: role:readonly and role:admin,
g, admin, role:adminThe Dex configuration file
The Dex configuration file contains the parameters required to configure SSO for ArgoCD.
ldap_connector.yaml), skip to Enabling the SSO for ArgoCD.
To configure SSO through LDAP, take the following steps:
After preparing the RBAC and the Dex configuration file, you can enable SSO for ArgoCD:
Update the
cluster_config.jsonfile with the following parameters:-
fabric.argocd_dex_config_file- enter the path to the previously created Dex configuration file. -
fabric.argocd_rbac_config_file- enter the path to the previously created RBAC file.
- Create the prerequisites required for the shared components installation, by running the following command:
./bin/uipathctl prereq create /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl prereq create /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json - Validate the prerequisites required by the shared components installation, by running the following command:
./bin/uipathctl prereq run /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl prereq run /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json -
Rerun the installer:
./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json
