- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated Dec 23, 2025
DescriptionPods using LH volume are stuck in Init:0/X (where X is an integer representing the number of containers), and the kubectl describe command on the pod returns MapVolume.MapPodDevice failed for volume in events.
To fix this issue, run the following command:
for podPv in $(kubectl get events -A -o json | jq -r '.items[] | select(.reason == "FailedMapVolume" and .involvedObject.kind == "Pod" and (.message | contains("MapVolume.MapPodDevice failed for volume") and contains("Could not mount \"/dev/longhorn"))) | .involvedObject.namespace + "=" + .involvedObject.name + "=" + (.message | match("(pvc-[0-9a-z-]+)").captures[0].string )') ; do
echo "Found 'FailedMapVolume' error: '${podPv}'"
NS=$(echo "${podPv}" | cut -d'=' -f1)
POD=$(echo "${podPv}" | cut -d'=' -f2)
PV=$(echo "${podPv}" | cut -d'=' -f3)
[[ -z "${NS}" ]] && echo "Could not extract namespace for error: '${podPv}'" && continue
[[ -z "${POD}" ]] && echo "Could not extract pod name for error: '${podPv}'" && continue
[[ -z "${PV}" ]] && echo "Could not extract Persistent Volume for error: '${podPv}'" && continue
controller_data=$(kubectl -n "${NS}" get po "${POD}" -o json | jq -r '[.metadata.ownerReferences[] | select(.controller==true)][0] | .kind + "=" + .name')
[[ -z "$controller_data" ]] && echo "Could not determine owner for pod: ${POD} in namespace: ${NS}" && continue
CONTROLLER_KIND=$(echo "${controller_data}" | cut -d'=' -f1)
[[ -z "${CONTROLLER_KIND}" ]] && echo "Could not extract controller kind for pod: '${POD}' in namespace: '${NS}' && continue
CONTROLLER_NAME=$(echo "${controller_data}" | cut -d'=' -f2)
[[ -z "${CONTROLLER_NAME}" ]] && echo "Could not extract controller name for pod: '${POD}' in namespace: '${NS}' && continue
if [[ $CONTROLLER_KIND == "ReplicaSet" ]]
then
controller_data=$(kubectl -n "${NS}" get "${CONTROLLER_KIND}" "${CONTROLLER_NAME}" -o json | jq -r '[.metadata.ownerReferences[] | select(.controller==true)][0] | .kind + "=" + .name')
[[ -z "${CONTROLLER_KIND}" ]] && echo "Could not extract controller kind(from rs) for pod: '${POD}' in namespace: '${NS}'" && continue
[[ -z "${CONTROLLER_NAME}" ]] && echo "Could not extract controller name(from rs) for pod: '${POD}' in namespace: '${NS}'" && continue
fi
org_replicas=$(kubectl -n "${NS}" get "$CONTROLLER_KIND" "$CONTROLLER_NAME" -o json | jq -r '.status.replicas')
echo "Scaling down ${CONTROLLER_KIND}/${CONTROLLER_NAME}"
kubectl -n "${NS}" patch "$CONTROLLER_KIND" "${CONTROLLER_NAME}" -p "{\"spec\":{\"replicas\":0}}"
if kubectl -n "${NS}" get pod "${POD}" ; then
kubectl -n "${NS}" wait --for=delete pod "${POD}" --timeout=300s
fi
if kubectl get volumeattachment | grep -q "${PV}"; then
volumeattachment_id=$(kubectl get volumeattachment | grep "${PV}" | awk '{print $1}')
kubectl delete volumeattachment ${volumeattachment_id}
fi
[[ -z "$org_replicas" || "${org_replicas}" -eq 0 ]] && org_replicas=1
echo "Scaling up ${CONTROLLER_KIND}/${CONTROLLER_NAME}"
kubectl -n "${NS}" patch "$CONTROLLER_KIND" "${CONTROLLER_NAME}" -p "{\"spec\":{\"replicas\":${org_replicas}}}"
donefor podPv in $(kubectl get events -A -o json | jq -r '.items[] | select(.reason == "FailedMapVolume" and .involvedObject.kind == "Pod" and (.message | contains("MapVolume.MapPodDevice failed for volume") and contains("Could not mount \"/dev/longhorn"))) | .involvedObject.namespace + "=" + .involvedObject.name + "=" + (.message | match("(pvc-[0-9a-z-]+)").captures[0].string )') ; do
then
fi
fi
fi
done
