- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
This article walks you through the core concepts and architecture of Automation Suite disaster recovery, covering Active/Passive and Active/Active deployments.
Ensuring continuous business automation is at the core of any automation platform. Automation Suite can withstand the complete failure of nodes, entire data centers, or regions. You can deploy Automation Suite as an Active/Active or an Active/Passive configuration.
Both configurations require the two clusters to have a High Availability Add-on license.
Automation Suite multi-site deployments in Active/Passive or Active/Active mode support the following scenarios:
- Same-site deployment - Two Automation Suite clusters deployed in the same site or data center;
- Cross-site deployment - Two Automation Suite clusters deployed in different data centers;
- Same-region deployment - Two Automation Suite clusters deployed in the same region either in the same data center or in different data centers in the same area;
- Cross-region deployment - Two Automation Suite clusters deployed in different regions.
For Active/Active configurations, you must ensure the round trip latency is under 10ms between both the Automation Suite clusters.
The following table provides details on which Automation Suite products you can deploy in Active/Passive and Active/Active mode.
| Product | Support for Active/Passive or Active/Active mode |
| Orchestrator | ✅ |
| Action Center | ✅ |
| AI Center | ✅ |
| Apps | ✅ |
| Automation Ops | ✅ |
| Automation Suite Robots | ✅ |
| Computer Vision | ✅ |
| Data Service | ✅ |
| Document Understanding | ✅ |
| Test Manager | ✅ |
| Automation Hub | ❌ |
| Insights | ❌ |
| Process Mining | ❌ |
| Task Mining | ❌ |
- You can install products that are not supported in Disaster Recovery with Active/Passive and Active/Active. However, you cannot use these products when the primary cluster is down.
- To deploy all the Automation Suite products in Active/Active mode, refer to High Availability - Three availability zones.
