- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
The interactive installer automatically creates databases using the following workflow:
The interactive installer script checks the value of the
sql.create_db
parameter in thecluster_config.json
file.-
If the
sql.create_db
parameter is set totrue
, the installer automatically generates all the databases on your behalf. In this case, the installer uses the default database names and default templates, and ignores any custom database names you provided.For details, see Automatically create the necessary databases.
If
sql.create_db
is set tofalse
, you must bring your own databases. In this case, you must manually set up your databases. Note that you can use custom database names, provided that you follow the provided naming conventions. This step is critical because we use the database name in conjunction with the connection template to form the database connection string. If you do not follow the recommended naming convention, you must provide the SQL connection strings yourself.For details, see Bring your own databases.
The interactive installer generates the connection strings as follows:
If you did not define a connection string for your service, the installer uses the connection template to generate all database connection strings.
If you defined a connection string for your service, the installer uses the provided connection string for your database.
If you want the installer to create the databases, fill in the following fields of the cluster_config.json
file:
Parameter |
Description |
Set to
true to allow the installer to create the databases. Note that the installer uses the default database names and default templates,
FQDN of the SQL server, where you want the installer to configure database. |
Port number on which a database instance should be hosted in the SQL server. |
Username / user ID to connect to the SQL server. |
Password of the username provided earlier to connect to the SQL server. |
Ensure the user has the
dbcreator
role. This grants them permission to create the database in SQL Server. Otherwise, the installation fails. -
ODBC connection does not support usernames that contain special characters. For database usernames for AI Center, Document Understanding, and Apps, use only uppercase and lowercase letters.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
If you bring your own database, you must provide the SQL connection strings for every database. Automation Suite supports the following SQL connection string formats:
Parameter |
Description |
Products |
Full ADO.NET connection string where Catalog name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. |
Platform Orchestrator Automation Suite Robots Test Manager Automation Hub Automation Ops Insights Integration Service Studio Web Task Mining Data Service Process Mining Document Understanding |
Full JDBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. |
AI Center 1 |
Full ODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. |
Document Understanding Apps |
Full SQL alchemy PYODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services. |
Document Understanding Process Mining |
sql_connection_string_template_jdbc
: encrypt=true;trustServerCertificate=false;fips=true;
db_securityadmin
and db_owner
roles for all Automation Suite databases. If security restrictions do not allow the use of db_owner
, then the SQL account should have the following roles and permissions on all databases:
db_securityadmin
db_ddladmin
db_datawriter
db_datareader
EXECUTE
permission on dbo schema
db_securityadmin
and db_ddladmin
roles during installation or if the databases are reprovisioned, so you may revoke these permission afterwards.
db_owner
role to be assigned for a successful installation.
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, ODBC, or PYODBC passwords as follows:
- for SQL: add
at the beginning and end of the password, and double any other'
. - for JDBC/ODBC: add
at the beginning of the password and}
at the end, and double any other}
. - for PYODBC:
username
andpassword
should be url encoded to account for special characters. Document Understanding database passwords cannot start with{
AutomationSuite_ProcessMining_Airflow
database for Process Mining product must have READ_COMMITTED_SNAPSHOT
enabled.
TrustServerCertificate
is set to False
, and you must provide an additional CA certificate for the SQL Server. This is required if the SQL Server certificate is
self-signed or signed by an internal CA. If you do not provide the SQL Server certificate in this scenario, the prerequisite
check will fail.
See Certificate configuration on this page for more details.
sql_connection_string_template example
Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
sql_connection_string_template_jdbc example
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
sql_connection_string_template_odbc example
SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"
sql_connection_string_template_sqlalchemy_pyodbc example
mssql+pyodbc://testuser%40sfdev3082457-sql.database.windows.net:_-%29X07_%5E3-%28%3B%25e-T@sfdev3082457-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
sql_connection_string_template and sql_connection_string_template_sqlalchemy_pyodbc example (Process Mining)
"sql_connection_string_template": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='07<l[xj-=~:z`Ds&nl';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
Default and optional DB names for Automation Suite services
"orchestrator": "AutomationSuite_Orchestrator",
"orchestrator_ta": "AutomationSuite_Orchestrator",
"asrobots": "AutomationSuite_Orchestrator",
"orchestrator_upd": "AutomationSuite_Platform",
"platform": "AutomationSuite_Platform",
"test_manager": "AutomationSuite_Test_Manager",
"automation_ops": "AutomationSuite_Platform",
"automation_hub": "AutomationSuite_Automation_Hub",
"insights": "AutomationSuite_Insights",
"task_mining": "AutomationSuite_Task_Mining",
"dataservice": "AutomationSuite_DataService",
"aicenter": "AutomationSuite_AICenter",
"documentunderstanding": "AutomationSuite_DU_Datamanager",
"processmining_airflow": "AutomationSuite_Airflow",
"processmining_metadata": "AutomationSuite_ProcessMining_Metadata",
"processmining_warehouse": "AutomationSuite_ProcessMining_Warehouse",
"apps": "AutomationSuite_Apps",
sql_connection_str
for that specific service.
You still have to manually create these databases before running the installer.
Overriding the default connection string for Orchestrator and the platform
"orchestrator": {
"sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomOrchDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"platform": {
"sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomIDDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"orchestrator": {
"platform": {
sql_connection_str
in the corresponding product blocks. The connection string should have a format supported by the respective product.
Example for setting database connection string for AI Center
Parameter |
Description |
AI Center JDBC connection string (Refer below for the JDBC format) |
"aicenter": {
"enabled": true,
"sql_connection_str": "jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net;database=aicenter;user=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;password=TFgID_9GsE7_P@srCQp0WemXX_euHQZJ"
"aicenter": {
"enabled": true,
Sample Document Understanding connection string
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "Server=SERVER_PLACEHOLDER;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=USER_PLACEHOLDER;Password='PASSWORD_PLACEHOLDER';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"datamanager": {
"sql_connection_str": "SERVER=SERVER_PLACEHOLDER;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=USER_PLACEHOLDER;PWD={PASSWORD_PLACEHOLDER};;Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=customer-sql.database.windows.net",
"pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sql.database.windows.net:Z%3Aw%21%zE%3Cb4@sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
"enabled": true,
"datamanager": {
For more information, check the Document Understanding configuration file.
Sample Process Mining connection string
"processmining": {
"enabled": true,
"app_security_mode": "system_managed",
"warehouse": {
"sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='password';Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
"master_sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
"sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='password';Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
"enabled": true,
"warehouse": {
and the PYODBC connection string sqlalchemy_pyodbc_sql_connection_str
used when you bring your own database are different. Also connection string names are different for the template SQL sql_connection_string_template
used when you bring your own database.
sql_connection_str
and sqlalchemy_pyodbc_sql_connection_str
connection strings in the processmining
section of the cluster_config.json
file, the template connection strings sql_connection_string_template
are ignored if specified.
MultiSubnetFailover=True
is not supported. Make sure to remove MultiSubnetFailover=True
from any of the Process Mining connection strings.
app_security_mode
setting either a new SQL user is created for every Process Mining app by the system (app_security_mode="system_managed"
), or a single SQL user account is created that is used for all process apps (app_security_mode="single_account"
). Note that app_security_mode="system_managed"
is the default setting, and that this requires advanced permissions for the database user.
Scenario: setup with Kerberos authentication.
"processmining": {
"enabled": true,
"warehouse": {
"sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
"master_sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes"
"processmining": {
"enabled": true,
"warehouse": {
Scenario: Metadata database and data warehouse use separate SQL server (Non-Kerberos authentication).
"processmining": {
"enabled": true,
"warehouse": {
"sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration1.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
"master_sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration2.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
"sql_connection_str": "Server=tcp:uipath-integration2.database.windows.net,1433;Initial Catalog=AutomationSuite_Airflow;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
"enabled": true,
"warehouse": {
Scenario: using custom
app_security_mode
"processmining": {
"enabled": true,
"warehouse": {
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=YES"
"processmining": {
"enabled": true,
"warehouse": {
