- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
AWS Marketplace deployment parameters
This page documents the AWS parameters you need to configure when deploying Automation Suite to AWS.
Parameter label (name) |
Default value |
Description |
Deploy to an existing VPC |
Choose
true to deploy Automation Suite in an
existing VPC.
Default value |
Description |
VPC CIDR |
VPC CIDR block. Example:
x.y.0.0/16 , x.y.z.0/24 .
VPC ID |
ID of the existing VPC. |
Public subnet IDs |
List of public subnet IDs to deploy the internet-facing Load Balancer and the Bastion host. |
Private Subnet IDs |
List of private subnet IDs. |
Default value |
Description |
Availability Zones |
Choose up to three Availability Zones to use for the VPC subnets. |
Default value |
Description |
Number of Availability Zones |
Choose the number of Availability Zones to use in the VPC. This must match the number of zones selected in the Availability Zones parameter. |
Deploy Bastion host |
Deploy a Bastion host inside the public subnet. |
CIDR for bastion's ingress for SSH traffic |
Ingress Security Group CIDR (for SSH). Configure this parameter only if you have set the Deploy Bastion host parameter to
true . Set to x.x.x.x/32 to allow one specific IP address access, 0.0.0.0/0 to allow all IP addresses access, or another CIDR range.
Default value |
Description |
Server instance type |
Choose the node type for the Server node instances. |
Server instance count |
Choose the number of nodes to be deployed as Server node instances. |
Agent instance type |
Choose the node type for the Agent node instances. |
Agent instance count |
Choose the number of nodes to be deployed as Agent node instances. |
GPU agent instance type |
Choose the node type for the GPU Agent node instance. |
Task Mining agent instance type |
Choose the node type for the Task Mining Agent node instance. |
AS Robots agent instance type |
Choose the node type for the AS Robots Agent node instance. |
AS Robots agent instance count |
Choose the number of nodes to be deployed as AS Robots Agent node instances. |
Default value |
Description |
Instance key pair |
Existing key pair to connect to virtual machine (VM) instances. |
IAM role ARN |
ARN of a pre-deployed IAM Role with sufficient permissions for the deployment. Leave empty to create a new role automatically during deployment. |
IAM role name |
Name of a pre-deployed IAM role with sufficient permissions for the deployment. Leave empty to create a new role automatically during deployment. |
Default value |
Description |
Enable cluster backup |
Enable the cluster backup. |
Use a shared bucket for external storage |
Enable a shared bucket across products. If enabled, Process Mining and Data Service still require a dedicated bucket each. |
Load balancer |
Select either an Application Load Balancer (ALB) or a Network Load Balancer (NLB). If you select a Network Load Balancer, then you need to manually configure the TLS certificates post deployment. |
Ingress Security Group CIDR (for https) | Empty string | Ingress Security Group CIDR (for HTTPS). Set the CIDR to
allow access to Automation Suite. Set the CIDR to
another CIDR range.
Perform installation |
Perform the Automation Suite installation. Choose
false to perform only infrastructure provisioning and configuration.
Automation Suite version |
e.g.
2023.10.1 |
Automation Suite version to install |
Add GPU-enabled VMs |
Choose
true to add a GPU-enabled VM to the deployment.
Extra configuration keys |
Extra configuration keys to add to the cluster configuration. Leave empty to use the default configuration. |
Validity of the self-signed certificate |
| Validity (in days) of the self-signed certificate that the deployment uses to encrypt traffic inside the VPC. |
Disable presigned URL |
Enable or disable objectstore access via pre-signed URLs. |
Default value |
Description |
External registry Fully Qualified Domain Name |
FQDN for the external registry. Leave empty to not use an external registry. |
External registry user name |
User name for connecting to the external registry. Leave empty to not use an external registry. |
External registry password |
Password for connecting to the external registry. Leave empty to not use an external registry. |
Default value |
Description |
Service install flags (multiple) |
Choose if a specific service is installed in the cluster. |
Default value |
Description |
Connect AI Center to an external Orchestrator |
Register AI Center to an external Orchestrator. |
Orchestrator URL |
URL of the external Orchestrator to which AI Center connects. Example:
https://my-orchestrator.net |
Identity URL |
URL of the Identity server used to authorize AI Center. Example:
https://my-orchestrator.net/identity |
Base64 encoded Orchestrator certificate |
Base64 encoded Orchestrator certificate string Example:
UExBQ0VIT0xERVI= |
Base64 encoded Identity certificate |
Base64 encoded Identity certificate string Example:
UExBQ0VIT0xERVI= |
Default value |
Description |
Hosting FQDN |
Fully qualified domain name (FQDN) for Automation Suite. This must be either a subdomain or root domain of the
ID of Amazon Route 53-hosted zone parameter.
ID of Amazon Route 53-hosted zone |
Enter the ID of the Amazon Route 53-hosted zone or leave blank. For details, see Valid domain name. |
ARN of the ACM-hosted certificate |
ARN of the certificate present in the Amazon Certificate Manager (ACM) to use with the ALB. Leave empty to create the public certificate during deployment. |
Use internal load balancer |
Choose if you want to use an internal load balancer. |
Default value |
Description |
Engine of SQL Server deployed on Amazon RDS |
Choose the Amazon Relational Database Service (Amazon RDS) SQL engine |
Version of SQL Server deployed on Amazon RDS |
Choose the Amazon RDS SQL version. |
AWS KMS Key Id used to encrypt Amazon RDS storage |
KMS Key ID to use for the encryption of the Amazon RDS storage. Leave empty to skip encrypting the Amazon RDS storage. |
- Table 1. Network choice
- Table 2. Network configuration
- Table 3. Availability Zone configuration
- Table 4. Common networking configuration
- Table 5. Automation Suite node configuration
- Table 6. Automation Suite instance configuration
- Table 7. Automation Suite deployment configuration
- Table 8: Automation Suite external registry configuration
- Table 9. Automation Suite service configuration
- Table 10. Automation Suite external Orchestrator configuration
- Table 11. DNS or SSL configuration
- Table 12. Amazon RDS configuration
