- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
This page provides instructions on the operations you can perform after deploying Automation Suite to AWS.
- Under CloudFormation > Stacks, you can find all of your deployments.
- Select the stack you deployed, a status of CREATE_COMPLETE indicates the deployment has completed successfully.
The installation process generates self-signed certificates on your behalf. By default, these certificates expire after 1825 days, but you can choose any of the following expiry periods at the time of deployment: 90, 365, 730, 1825, or 3650 days.
You must replace the self-signed certificates with certificates signed by a trusted Certificate Authority (CA) as soon as the installation completes. If you do not update the certificates, the installation will stop working after the certificate expiry date.
For instructions, see Managing certificates.
/root/installer directory.
The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
- Go to the following URL:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Default organization.
- The username is orgadmin.
- Retrieve the password by selecting the secrets link provided in the output table for AutomationSuiteSecret. Go to Retrieve Secret Value for the credentials.
The host portal is where system administrators configure the Automation Suite instance. The settings configured from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Host organization.
- The username is admin.
- Retrieve the password by selecting the secrets link provided in the output table for HostAdministrationSecret. Go to Retrieve Secret Value for the credentials.
You can use the ArgoCD console to manage installed products.
To access ArgoCD, take the following steps:
https://alm.${CONFIG_CLUSTER_FQDN}. - The username is admin.
- Retrieve the password by clicking to the secrets link provided in the output table for ArgoCdSecret. Go to Retrieve Secret Value for the credentials.
Automation Suite uses Rancher to provide cluster management tools out of the box. This helps you manage the cluster and access monitoring and troubleshooting.
For more details, see Rancher documentation.
For more on how to use Rancher monitoring in Automation Suite, see Using the monitoring stack.
To access the Rancher console, take the following steps:
