- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Step 3: Post-deployment steps
This page provides instructions on the operations you can perform after deploying Automation Suite to AWS.
Validating the installation
- Under CloudFormation > Stacks, you can find all of your deployments.
- Select the stack you deployed, a status of CREATE_COMPLETE indicates the deployment has completed successfully.
Updating Certificates
The installation process generates self-signed certificates on your behalf. By default, these certificates expire after 1825 days, but you can choose any of the following expiry periods at the time of deployment: 90, 365, 730, 1825, or 3650 days.
You must replace the self-signed certificates with certificates signed by a trusted Certificate Authority (CA) as soon as the installation completes. If you do not update the certificates, the installation will stop working after the certificate expiry date.
For instructions, see Managing certificates.
Accessing the installer package
In AWS deployments, the installer package containing all the scripts for post-deployment operations is decompressed in the /root/installer directory.
Accessing the Deployment Outputs
From the Stack you selected, click the Output tab on the top. On this tab, you should have access to all the information you need for next steps.
For any of the credentials, you can access them via the secrets link provided in the table. Click on the link and go to Retrieve Secret Value for the credentials.
Key Value Description ArgoCD https://alm.${CONFIG_CLUSTER_FQDN}You can use the ArgoCD console to manage installed products. ArgoCD Secret < See link in console > Credentials for ArgoCD Automation Suite Secret < See link in console > Credentials for Automation Suite Portal Automation Suite URL https://${CONFIG_CLUSTER_FQDN}Automation Suite Portal Host Administration Portal https://${CONFIG_CLUSTER_FQDN}The host portal is for system administrators to configure the Automation Suite instance. The settings that you configure from this portal are inherited by all your organizations, and some can be overwritten at the organization level. Host Administration Secret < See link in console > Credentials for Host Administration Interface Tour Interface tour The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all the Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages. Rancher https://monitoring.${CONFIG_CLUSTER_FQDN}Automation Suite uses Rancher to provide cluster management tools out of the box. This helps you manage the cluster and access monitoring and troubleshooting.
Accessing the Automation Suite portal
The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
- Go to the following URL:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Default organization.
- The username is orgadmin.
- Retrieve the password by selecting the secrets link provided in the output table for AutomationSuiteSecret. Go to Retrieve Secret Value for the credentials.
Accessing host administration
The host portal is where system administrators configure the Automation Suite instance. The settings configured from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Host organization.
- The username is admin.
- Retrieve the password by selecting the secrets link provided in the output table for HostAdministrationSecret. Go to Retrieve Secret Value for the credentials.
Accessing ArgoCD
To access ArgoCD, take the following steps:
https://alm.${CONFIG_CLUSTER_FQDN}. - The username is admin if you want to use the ArgoCD admin account, or argocdro if you want to use the ArgoCD read-only account.
- Retrieve the password by selecting to the secrets link provided in the output table for ArgoCdSecret. Go to Retrieve Secret Value for the credentials.
Accessing Rancher
For more details, see Rancher documentation.
For more on how to use Rancher monitoring in Automation Suite, see Using the monitoring stack.
To access the Rancher console, take the following steps:
https://monitoring.${CONFIG_CLUSTER_FQDN} -
To access the password, run the following command on a server node:
kubectl get secrets/rancher-admin-password -n cattle-system \ -o "jsonpath={.data['password']}" | echo $(base64 -d)kubectl get secrets/rancher-admin-password -n cattle-system \ -o "jsonpath={.data['password']}" | echo $(base64 -d)Note:Make sure kubectl is enabled. For more information, see Accessing Automation Suite.
Accessing cluster VMs
Navigate to EC2 and find your Automation Suite instance(s) depending if you deployed single-node or multi-node.
Find the public IP of the Bastion or instance you want to connect to.
Open a terminal and use SSH to connect to Bastion.
ssh -i <path_to_private_key> <username>@<bastion_ip>ssh -i <path_to_private_key> <username>@<bastion_ip> -
From Bastion, you can access other nodes via SSH using the following command. The username must be the same as the one used to connect to Bastion.
ssh -i .ssh/private_key <username>@<node_address>ssh -i .ssh/private_key <username>@<node_address>
Performing Cluster Operations
The templates provide automations for cluster operations leveraging Systems Manager documents:
UpdateAMIDocument
The SSM document creates a new Launch Template version for the server and agent Automatic Scaling Groups with an updated AMI ID.
Usage
The document exposes 2 parameters:
ImageName(e.g.:RHEL-8.3*_HVM-20*) – If theImageNameparameter is provided and AMI that matches theImageNamewill be set on the Automatic Scaling Groups;AmiId(e.g.:ami-032e5b6af8a711f30) – If provided, theAmiIdtakes precedence overImageNameand is set on the Automatic Scaling Groups.
If you did not use a custom AMI at deployment time, you can leave the parameters empty. In this case, the ImageName stored in Parameter Store is used as default value.
