- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
This page provides instructions on the operations you can perform after deploying Automation Suite to AWS.
- Under CloudFormation > Stacks, you can find all of your deployments.
- Select the stack you deployed, a status of CREATE_COMPLETE indicates the deployment has completed successfully.
The installation process generates self-signed certificates on your behalf. By default, these certificates expire after 1825 days, but you can choose any of the following expiry periods at the time of deployment: 90, 365, 730, 1825, or 3650 days.
You must replace the self-signed certificates with certificates signed by a trusted Certificate Authority (CA) as soon as the installation completes. If you do not update the certificates, the installation will stop working after the certificate expiry date.
For instructions, see Managing certificates.
/root/installer directory.
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, see Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
https://${CONFIG_CLUSTER_FQDN}/uipath-management.The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
- Go to the following URL:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Default organization.
- The username is orgadmin.
- Retrieve the password by selecting the secrets link provided in the output table for AutomationSuiteSecret. Go to Retrieve Secret Value for the credentials.
The host portal is where system administrators configure the Automation Suite instance. The settings configured from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Host organization.
- The username is admin.
- Retrieve the password by selecting the secrets link provided in the output table for HostAdministrationSecret. Go to Retrieve Secret Value for the credentials.
You can use the ArgoCD console to manage installed products.
To access ArgoCD, take the following steps:
https://alm.${CONFIG_CLUSTER_FQDN}. - The username is admin if you want to use the ArgoCD admin account, or argocdro if you want to use the ArgoCD read-only account.
- Retrieve the password by selecting to the secrets link provided in the output table for ArgoCdSecret. Go to Retrieve Secret Value for the credentials.
Automation Suite uses Rancher to provide cluster management tools out of the box. This helps you manage the cluster and access monitoring and troubleshooting.
For more details, see Rancher documentation.
For more on how to use Rancher monitoring in Automation Suite, see Using the monitoring stack.
To access the Rancher console, take the following steps:
The templates provide automations for cluster operations leveraging Systems Manager documents.
Using Systems Manager documents
To use the Systems Manager documents, take the following steps:
UpdateAMIDocument
The SSM document creates a new Launch Template version for the server and agent Automatic Scaling Groups with an updated AMI ID.
Usage
The document exposes 2 parameters:
ImageName(e.g.:RHEL-8.6*_HVM-20*) – If theImageNameparameter is provided and AMI that matches theImageNamewill be set on the Automatic Scaling Groups;AmiId(e.g.:ami-032e5b6af8a711f30) – If provided, theAmiIdtakes precedence overImageNameand is set on the Automatic Scaling Groups.
ImageName stored in Parameter Store is used as default value.
RegisterAiCenter
The SSM document registers AI Center to the external Orchestrator provided at deployment time.
Usage
IdentityToken, which is an installation access token generated by the external Identity service. Since the token has a short availability
(approximately 1-2 hours), we recommend generating it just before running the SSM document. For instructions, see Installation key.
OnDemandBackup
Creates a snapshot of the Automation Suite cluster. Does not perform a backup on the SQL server.
Usage
This SSM document does not require any parameters.
Execution logs
captureOnDemandBackup step.
GetAllBackups
Lists all snapshot available in the Automation Suite cluster.
Usage
Execution logs
getSnapshotList step.
OnDemandRestore
Restores the Automation Suite cluster to a snapshot.
Usage
SnapshotName parameter. To get a snapshot, use the GetAllBackups document and check the logs.
Execution logs
To view the execution logs, take the following steps:
After performing an Automation Suite cluster upgrade, AWS template deployments require some changes to ensure a new node joins the cluster correctly. To automate the changes, we recommend using the dedicated script. For instructions, see the AWS deployment template docs.
- Validating the installation
- Updating Certificates
- Accessing the installer package
- Accessing the deployment outputs
- Accessing the Cluster Administration portal
- Accessing the Automation Suite portal
- Accessing host administration
- Accessing ArgoCD
- Accessing Rancher
- Accessing cluster VMs
- Performing cluster operations
- Using Systems Manager documents
- UpdateAMIDocument
- RegisterAiCenter
- OnDemandBackup
- GetAllBackups
- OnDemandRestore
- Completing an upgrade
