2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Release Notes
18 August 2023
| AWS template version | 2022.4.5 |
| Automation Suite version | 2022.4.2 |
What's new
We have made some minor changes to the way you configure the Partner Solution S3 bucket configuration section. You must manually modify the Template-hosting S3 Region parameter to match exactly the AWS region in which you try to deploy.
14 October 2022
What’s New
- You can now use the AWS deployment template to install Automation Suite 2022.4.2.
Bug Fixes
- The installation of GPU drivers did not properly complete.
7 September 2022
| AWS template version | 2022.4.4 |
| Automation Suite version | 2022.4.1 |
Improvements
- The disk size and IOPS requirements imposed by the AWS template are now in accordance with the Hardware and software requirements page.
- You can use AWS templates, even if you do not have a hosted zone in AWS Route 53. Read more in our documentation.
Bug Fixes
- Now the VPCCIDR validation succeeds for both root and nested stacks.
11 August 2022
| AWS template version | 2022.4.3 |
What’s New
- You can now use the AWS deployment template to install Automation Suite 2022.4.1.
27 July 2022
| AWS template version | 2022.4.2 |
| Automation Suite version | 2022.4.0 |
Bug Fixes
- The launch lifecycle hook was never completed, leading to failure during post-installation scale-out operations.
25 July 2022
| AWS template version | 2022.4.1 |
What’s New
- We have added an SSM document that updates the AMI ID for the server and agent Automatic Scaling Groups. For more details, see Performing cluster operations section.
Improvements
- We now expose logs for the GPU node installation in CloudWatch.
- Following a successful installation, newly created instances transition in the
InServicestate.
Bug Fixes
- The GPU node installation failure now sends a fail signal instead of timing out.
16 June 2022
| AWS template version | 2022.4.0 |
Improvements
- We have changed the pattern for the
VPC CIDRparameter to allow/24.
27 May 2022
What’s New
- You can now install Data Service via the AWS deployment template.
- We now offer support for instance lifecycle hooks. This will automatically remove nodes gracefully when termination occurs.
- You can now use both an admin and a read-only ArgoCD account. Output are available for both options.
