- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Release Notes
18 August 2023
| AWS template version | 2021.10.2 |
| Automation Suite version | 2021.10.4 |
What's new
We have made some minor changes to the way you configure the Partner Solution S3 bucket configuration section. You must manually modify the Template-hosting S3 Region parameter to match exactly the AWS region in which you try to deploy.
9 August 2022
Improvements
We have changed the Python version used in Lambda functions from 3.6 to 3.9.
11 May 2022
| AWS template version | 2021.10.1 |
Improvements
- We have updated the hardware requirements.
- We have expanded the accepted CIDR range for existing VPC.
- We have added special character escaping to SQL connection string passwords.
- We have made some minor description changes.
28 April 2022
| AWS template version | 2021.10.0 |
What’s New
- The AWS deployment template is now versioned, and you can start monitoring this page to keep an eye on what's new.
