- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
| AWS template version | 2022.10.5 |
| Automation Suite version | 2022.10.5 |
What's new
We have made some minor changes to the way you configure the Partner Solution S3 bucket configuration section. You must manually modify the Template-hosting S3 Region parameter to match exactly the AWS region in which you try to deploy.
What's new
You can now install Automation Suite 2022.10.5 using the AWS deployment template.
| AWS template version | 2022.10.4 |
| Automation Suite version | 2022.10.2 |
What's new
The AWS deployment template now provides support for external object storage.
Bug fixes
We have fixed an issue causing ArgoCD not to be accessible when the installation of services failed.
| AWS template version | 2022.10.3 |
| Automation Suite version | 2022.10.1 |
What’s New
The AWS deployment template now provides support for upgrades to newer Automation Suite versions.
upgrade_wrapper.py script. For more details and instructions, see Completing an upgrade.
What’s New
- You can now install Automation Suite 2022.10.1 using the AWS deployment template.
Bug Fixes
- We have fixed a bug causing a disk to be misconfigured for some custom AMIs.
| AWS template version: | 2022.10.2 |
| Automation Suite version | 2022.10.0 |
Bug Fixes
- We have fixed an issue causing external Orchestrator parameters to be displayed incorrectly in the UI.
| AWS template version | 2022.10.1 |
Bug Fixes
- The
ManagementStackfailed to create when using a custom AMI. - The
ManagementStackcreated IAM roles instead of using the one provided as a parameter.
| AWS template version | 2022.10.0 |
What’s New
- You can now install new services using the AWS deployment template. Process Mining and Automation Suite Robots are the latest additions to the suite.
- You can now connect AI Center to an external Orchestrator. To do that, you must explicitly opt for this functionality and provide certificates for Orchestrator and Identity. For more instructions, see Step 1: Preparing the AWS deployment.
- You can now install strictly the products you are interested in using the AWS deployment template as we have deprecated the Basic product selection and made Orchestrator optional.
- We have introduced a new tool guiding you through the steps you need to take to complete the Automation Suite installation as well as common post-installation operations. It is called Cluster Administration, and it provides useful instructions on certificate configuration, Kerberos authentication setup, node administration, database maintenance, cluster monitoring, and more.
- The AWS template now defaults to using RHEL 8.6.
- We have some new Systems Manager documents for connecting AI Center to an external Orchestrator and for backup and restore operations. For more details, see Performing cluster operations.
Improvements
The hardware requirements for Automation Suite have been optimized. As a result, we have also made some changes to the AWS deployment architecture to reflect these improvements. For details, see Complete component list.
For details on how the template computes the required hardware, see Deployment and instance type mapping.
Following the deprecation of the the Basic product selection for Automation Suite, we now have two options to launch the AWS CloudFormation template:
- into a new VPC
- into an existing VPC
- We have made some changes to EC2 instance configuration for the server nodes. The disk configuration now includes an Objectstore disk, used for in-cluster storage.
- This release also brings various UX improvements.
Known Issues
Erratum: We have fixed the issue in AWS template version 2022.10.4, which installs Automation Suite 2022.10.2. For more details, see 27 February 2023 release notes.
- While Automation Suite now provides support for external storage, the AWS deployment template currently does not offer this functionality. For the time being, you need to continue using the in-cluster storage, but we are actively working on providing an alternative.
