OUT OF SUPPORT
Last updated Feb 24, 2025
Step 2: Deploying Automation Suite to GCP
Important: You can currently use the GCP deployment template only with Automation Suite 2024.10. We therefore recommend referring to the Automation Suite 2024.10 documentation.
This page describes the steps you need to take to deploy Automation Suite in GCP.
Important: Make sure to go through Step 1: Preparing the GCP deployment before proceeding.
Configuring the deployment
Once you prepare the GCP environment, you can directly deploy the infrastructure.
Take the following steps:
  1. Download the templates from here and unzip them.
  2. (Optional) Move the SSH keys generated at Step 1 in the templates folder.
  3. The unzipped templates include a terraform.tfvars file with the parameters. Edit them according to your deployment.
Deployment Parameters
Name
Parameter type
Example
project_id
Project in which the resources will be deployed.
string
my-gcp-project
region
Region where the resources will be deployed.
string
europe-west1
zone
Default zone where zonal resources are deployed. The zone should belong to the region you chose.
string
europe-west1-c
installer_version
Automation Suite installer version.
string
2021.10.3
installer_url
Automation Suite installer URL. It overwrites the installer_version parameter and installs the version from the package.
string
https://download.uipath.com/automation-suite/installer.zip
perform_installation
Automatically install Automation Suite on the provided infrastructure.
bool
lb_fqdn
Fully qualified domain name (FQDN) for Automation Suite.
string
my-fqdn.net
ssh_user
Username used to log in VMs via SSH.
string
user
ssh_pub_key_path
Path to the SSH public key used to access VMs.
string
gcp_key.pub
ssh_private_key_path
Path to the SSH private key used to access VMs.
string
gcp_key
server_instance_type
Instance type of server machines.
string
n2-standard-32
agent_instance_type
Instance type of agent machines.
string
n2-standard-16
gpu_instance_type
(Optional) Parameter used only if the number of GPU agents is at least 1. Instance type of GPU agent machines.
string
n1-standard-16
gpu_type
(Optional) Parameter used only if the number of GPU agents is at least 1. GPU type for the GPU nodes.
string
nvidia-tesla-t4
server_count
Number of server VMs, must be odd
number
3
agent_count
Number of agent VMs.
number
1
gpu_agent_count
Number of GPU agent VMs
number
1
vm_custom_image
(Optional) Name of the custom image you want to use for the VM's. Leave empty to default to latest RHEL 8 GCP image.
string
my-rhel8-image
install_aicenter
Install AI Center.
bool
install_documentunderstanding
Install Document Understanding.
bool
install_insights
Install Insights.
bool
install_test_manager
Install Test Manager.
bool
install_automation_ops
Install Automation Ops.
bool
install_automation_hub
Install Automation Hub.
bool
install_apps
Install Apps.
bool
install_action_center
Install Action Center.
bool
install_task_mining
Install Task Mining.
bool
accept_license_agreement
By setting the parameter as true, you agree to the applicable license agreement.
bool
Advanced configuration
If you want to add any new configuration that is exposed via cluster_config.json, follow these steps:
  1. Use your favorite text editor to edit the ./scripts/inputs_schema file from the unzipped package.
  2. Change or add the json file as required.
    Note: Keep in mind that Terraform will replace ${var} variables defined in the metadata.tf with their respective values when altering the inputs_schema file.
Completing the deployment
Once you set the parameters, take the following steps:
  1. Open a terminal and authenticate to GCP using the following command.
    gcloud auth application-default logingcloud auth application-default login
  2. In the terminal, go to the folder where you unzipped the templates and run the following commands:
    terraform init
    terraform applyterraform init
    terraform apply
  3. Type Yes when asked for approval. The deployment will then run. It usually takes between 1 to 1.5 hours to complete.
  • Configuring the deployment
  • Deployment Parameters
  • Advanced configuration
  • Completing the deployment
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
