- Overview
- Requirements
- Q&A: Deployment templates
- Release notes
- GCP deployment architecture
- Step 1: Preparing the GCP deployment
- Step 2: Deploying Automation Suite to GCP
- Step 3: Post-deployment steps
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
You can currently use the GCP deployment template only with Automation Suite 2024.10. We therefore recommend referring to the Automation Suite 2024.10 documentation.
Make sure to go through Step 1: Preparing the GCP deployment before proceeding.
Configuring the deployment
Once you prepare the GCP environment, you can directly deploy the infrastructure.
Take the following steps:
- Download the templates from here and unzip them.
- (Optional) Move the SSH keys generated at Step 1 in the templates folder.
- The unzipped templates include a
terraform.tfvarsfile with the parameters. Edit them according to your deployment.
Deployment parameters
| Name | Description | Parameter type | Example |
project_id | Project in which the resources will be deployed. | string | my-gcp-project |
region | Region where the resources will be deployed. | string | europe-west1 |
zone | Default zone where zonal resources are deployed. The zone should belong to the region you chose. | string | europe-west1-c |
installer_version | Automation Suite installer version. | string | 2021.10.3 |
installer_url | Automation Suite installer URL. It overwrites the installer_version parameter and installs the version from the package. | string | https://download.uipath.com/automation-suite/installer.zip |
perform_installation | Automatically install Automation Suite on the provided infrastructure. | bool | true |
lb_fqdn | Fully qualified domain name (FQDN) for Automation Suite. | string | my-fqdn.net |
ssh_user | Username used to log in VMs via SSH. | string | user |
ssh_pub_key_path | Path to the SSH public key used to access VMs. | string | gcp_key.pub |
ssh_private_key_path | Path to the SSH private key used to access VMs. | string | gcp_key |
server_instance_type | Instance type of server machines. | string | n2-standard-32 |
agent_instance_type | Instance type of agents machines. | string | n2-standard-16 |
gpu_instance_type | (Optional) Parameter used only if the number of GPU agents is at least 1. Instance type of GPU agent machines. | string | n1-standard-16 |
gpu_type | (Optional) Parameter used only if the number of GPU agents is at least 1. GPU type for the GPU nodes. | string | nvidia-tesla-t4 |
server_count | Number of server VMs, must be odd | number | 3 |
agent_count | Number of agent VMs. | number | 1 |
gpu_agent_count | Number of GPU agent VMs | number | 1 |
vm_custom_image | (Optional) Name of the custom image you want to use for the VM's. Leave empty to default to latest RHEL 8 GCP image. | string | my-rhel8-image |
install_orchestrator | Install Orchestrator. | bool | true |
install_aicenter | Install AI Center. | bool | true |
install_documentunderstanding | Install Document Understanding. | bool | true |
install_insights | Install Insights. | bool | true |
install_data_service | Install Data Service | bool | true |
install_test_manager | Install Test Manager. | bool | true |
install_automation_ops | Install Automation Ops. | bool | true |
install_automation_hub | Install Automation Hub. | bool | true |
install_apps | Install Apps. | bool | true |
install_action_center | Install Action Center. | bool | true |
install_task_mining | Install Task Mining. | bool | true |
install_as_robots | Install Automation Suite Robots. | bool | true |
asrobots_agent_count | Instance type of ASobots dedicated agents. | number | 1 |
asrobots_agent_instance_type | Number of dedicate ASRobots VMs. | string | n2-standard-16 |
install_process_mining | Install Process Mining. | bool | true |
accept_license_agreement | By setting the parameter as true, you agree to the applicable license agreement. | bool | true |
Advanced configuration
If you want to add any new configuration that is exposed via cluster_config.json, follow these steps:
Use your favorite text editor to edit the
./scripts/inputs_schemafile from the unzipped package. -
Change or add the
jsonfile as required.Note:Keep in mind that Terraform will replace
${var}variables defined in themetadata.tfwith their respective values when altering theinputs_schemafile.
Completing the deployment
Once you set the parameters, take the following steps:
Open a terminal and authenticate to GCP using the following command.
gcloud auth application-default logingcloud auth application-default login -
In the terminal, go to the folder where you unzipped the templates and run the following commands:
terraform init terraform applyterraform init terraform apply -
Type
Yeswhen asked for approval. The deployment will then run. It usually takes between 1 to 1.5 hours to complete.
