- Overview
- Requirements
- Deployment templates
- Q&A: Deployment templates
- GCP Marketplace deployment architecture
- Step 1: Preparing the GCP Marketplace deployment
- Step 2: Deploying Automation Suite to GCP Marketplace
- Step 3: Post-deployment steps
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
GCP Marketplace deployment architecture for Automation Suite, including networking, DNS, and infrastructure components.
Architecture diagram
The following diagram shows the GCP Marketplace deployment architecture for Automation Suite.
Components
- Virtual network
- A subnet where all nodes reside.
- A NAT Gateway for outbound connectivity (a Cloud Nat resource attached to a Cloud Router);
- Firewall Rules to secure subnet traffic.
- A DNS private zone needed for installation. For details, refer to the Known limitations section.
- 4 Managed Instance Groups. You can choose the instance type for server, agent, GPU agent nodes, and Automation Suite Robots nodes. Make sure you meet the hardware requirements for each type of node. Each VM has a 128 GB OS and 256 GB cluster binaries and state disk. Server nodes have two additional disks: a 512GB data disk and a 512GB disk used for objectstore.
- Server nodes (cluster control plane). Server nodes also run workloads.
- Agent nodes. Designed to only run workloads (they have no control plane services). If the number of desired Agent nodes is 0, an empty Managed Instance Group is created.
- GPU nodes. Nodes used specifically for ML models that have video cards. If the number of desired GPU nodes is 0, no Managed Instance Group is created.
- Automation Suite Robots nodes. Designed to only run robot workloads. If the number of desired Automation Suite Robots nodes is 0, an empty Managed Instance Group is created. Automation Suite Robots nodes have an additional 32GB disk used for robot package caching.
- Public load balancer used to balance HTTPS traffic from port
443to nodes. - 2 Internal load balancers and a Managed Instance Group needed for forwarding node registration requests. The VMs have the smallest instance size possible.
- Bastion instance used to access the other nodes. It has a public IP and SSH enabled.
- SQL Database Instance:
- 8 cores and 32 GB RAM
- 1000 GB disk size that can be manually extended
- The databases are created by the installer
- A PostgreSQL Database Instance for Process Mining
AutomationSuite_Airflowdatabase.- 4 cores and 16GB RAM
- 64 GB disk size
- >=500 IOPS
- A secondary SQL Database Instance is deployed if Process Mining is installed and the cluster is HA (has at least 3 server nodes):
- 16 cores and 32 GB RAM
- 100 GB disk size that can be manually extended
- The database needed by Process Mining is created by the installer
- Secret Manager used to store auto-generated credentials for SQL server, Automation Suite Platform, and ArgoCD console.
- Service account used for the VM identities.
Known limitations
Process Mining
- Installation fails if you enable Process Mining in a multi-node HA-ready production mode. Make sure not to select Process Mining at installation time. You can enable Process Mining post-installation, after creating the
AutomationSuite_ProcessMining_Warehousedatabase. For details, refer to Managing products.
DNS
- Due to the fact that a DNS cannot be automatically attached to the LB:
- The steps for configuring DNS can be completed only after the installation, while they are needed during installation. The private DNS zone solves this issue and can be safely deleted after the installation is completed. Alternatively, for testing purposes check the Step 4: Configuring the DNS.
RHEL
- Google may update the RHEL version without notice, thus leaving Automation Suite deployments outside of support. Currently, manual deployments using custom RHEL images are the only way to and stay in support.
