- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Enabling SSO for ArgoCD
uipathctl.sh
script is required to enable SSO authentication. For more details on the script and the parameters you need to use, see Using uipathctl.sh.
You must generate the RBAC file and the connector file before enabling SSO for ArgoCD.
The RBAC file contains access rules. For details on the built-in role definitions, see ArgoCD documentation. For details on the ArgoCD account types and their permissions, see Managing the cluster in ArgoCD. We recommend using these roles when defining your groups, but you can create your own set of permissions.
Configuring the RBAC file
Example:
Say your LDAP group for ArgoCD administrators is "Administrators", and the LDAP group for ArgoCD read-only users is "Readers", the RBAC file should be:
p, role:uipath-sync, applications, get, */*, allow
p, role:uipath-sync, applications, sync, */*, allow
g, argocdro, role:uipath-sync
g, Readers, role:uipath-sync
g, Administrators, role:admin
For more advanced use cases, see the default RBAC file.
# Built-in policy which defines two roles: role:readonly and role:admin,
# and additionally assigns the admin user to the role:admin role.
# There are two policy formats:
# 1. Applications, logs, and exec (which belong to a project):
# p, <user/group>, <resource>, <action>, <project>/<object>
# 2. All other resources:
# p, <user/group>, <resource>, <action>, <object>
p, role:readonly, applications, get, */*, allow
p, role:readonly, certificates, get, *, allow
p, role:readonly, clusters, get, *, allow
p, role:readonly, repositories, get, *, allow
p, role:readonly, projects, get, *, allow
p, role:readonly, accounts, get, *, allow
p, role:readonly, gpgkeys, get, *, allow
p, role:readonly, logs, get, */*, allow
p, role:admin, applications, create, */*, allow
p, role:admin, applications, update, */*, allow
p, role:admin, applications, delete, */*, allow
p, role:admin, applications, sync, */*, allow
p, role:admin, applications, override, */*, allow
p, role:admin, applications, action/*, */*, allow
p, role:admin, applicationsets, get, */*, allow
p, role:admin, applicationsets, create, */*, allow
p, role:admin, applicationsets, update, */*, allow
p, role:admin, applicationsets, delete, */*, allow
p, role:admin, certificates, create, *, allow
p, role:admin, certificates, update, *, allow
p, role:admin, certificates, delete, *, allow
p, role:admin, clusters, create, *, allow
p, role:admin, clusters, update, *, allow
p, role:admin, clusters, delete, *, allow
p, role:admin, repositories, create, *, allow
p, role:admin, repositories, update, *, allow
p, role:admin, repositories, delete, *, allow
p, role:admin, projects, create, *, allow
p, role:admin, projects, update, *, allow
p, role:admin, projects, delete, *, allow
p, role:admin, accounts, update, *, allow
p, role:admin, gpgkeys, create, *, allow
p, role:admin, gpgkeys, delete, *, allow
p, role:admin, exec, create, */*, allow
g, role:admin, role:readonly
g, admin, role:admin
The LDAP connector file contains the LDAP parameters required to configure SSO for ArgoCD.
ldap_connector.yaml
), skip to Enabling the SSO for ArgoCD.
To configure SSO through LDAP, take the following steps:
After preparing the RBAC and the connector file, you can enable SSO for ArgoCD.
Enable the SSO for ArgoCD by running the following command in the directory where the connector file is stored:
./uipathctl.sh sso-apply-overlays --install-type [online|offline] --accept-license-agreement --sso-connector-file ldap_connector.yaml --sso-rbac-file policy.csv
