- Overview
- Requirements
- Q&A: Deployment Templates
- Release Notes
- Azure deployment architecture
- Step 1: Preparing the Azure Deployment
- Step 2: Deploying Automation Suite to Azure
- Step 3: Post-deployment Steps
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
This page offers an overview of the parameters you need to use when deploying Automation Suite to Azure.
Once you have the Azure environment set up, navigate to this link to install Automation Suite in your Azure environment.
The following table provides an overview of the parameters used in the deployment:
Parameter name |
Description |
Subscription |
The Azure subscription. |
Resource Group |
The Azure Resource Group, under the subscription. |
Region |
The default region of the Resource Group. |
Location |
A valid Azure Region where the infrastructure is deployed. Make sure that the region has enough cores for the instance types used. You can use the
[resourceGroup().location] if this is the same as the Resource Group’s region.
Automation Suite version |
The version of Automation Suite. Example:
21.10.2 |
Run Automation Suite Install |
Choose whether Automation Suite should be installed after the infrastructure is provisioned. |
Accept License Agreement |
By setting the parameter as true, you agree to the applicable license agreement. |
DNS Load Balancer |
The prefix used for the load balancer subdomain. If you use a custom domain you will only be able to access the cluster through the custom domain, not directly using the load balancer's domain (eg. <prefix>.<region>.cloudapp.azure.com). |
Virtual Network New Or Existing |
Parameter indicating whether the Virtual Network used for the deployment should be created or if it already exists. |
Existing Virtual Network Resource Group |
Resource group where the existing Virtual Network you want to use is deployed. Parameter used only if the
Virtual Network New Or Existing parameter is set to existing.
Existing Virtual Network Name |
Name of the existing Virtual Network used for deployment. Parameter used only if the
Existing Subnet Name |
Name of an existing subnet inside the previously mentioned Virtual Network. The subnet must satisfy these requirements. Parameter used only if the
Deploy Bastion Host |
Deploy a Bastion Host on the Virtual Network. Parameter used only if Virtual Network New Or Existing is set to new. |
Enable Custom Domain |
Please set to true if you want to use your own custom domain. The needs post-install configuration. |
Custom domain |
This is the domain you want to use for the cluster. Post-installation, create two CNAME/A records that will point to the public load balancer. See DNS configuration. |
Enable Custom Certificates |
Set to
true if you want to use your own custom certificates for your own domain. Make sure to use this together with the Enable Custom Domain parameter set to true.
Custom Server Certificate |
This is a
base64 encoded string.
Encode the contents of the
.crt server certificate to a base64 string. The server certificate should have the following properties.
Custom Server Cert Key |
This is a
.key server certificate key, to a base64 string. This is the private key from the Custom Server Certificate parameter.
Custom Server Cert Authority Bundle |
This is a
Create a
.crt file containing all public certificates (.crt) from all of the CA certificates in the Server Certificate chain (excluding the server certificate).
Create a
base64 string from the contents of this file.
Automation Suite Installer URL |
Optional: The link to the Automation Suite installation package. Changing this parameter will overwrite the
Automation Suite version parameter above and install the version specified in this URL.
Keep set to
None if not used.
Automation Suite Advanced Config |
This is a valid
json string that will be merged in the cluster_config.json file that is being built by the template. Will overwrite existing settings.
See advanced installation experience for details. |
Server Node Count |
The number of VMs created to work as the servers for the cluster. Should be an odd number. |
Server Node Instance Type |
The instance type for the server nodes. Example:
Standard_D16s_v3 |
Enable Ultra Disks |
Enable to use ultra disks for
etcd (server nodes). Should only be disabled if the region you are deploying to does not have zones support.
Agent Node Count |
The number of VMs created to serve as the agent nodes for the cluster. If 0, an empty agent scale set is still created. |
Agent Node Instance Type |
The instance type for the agent nodes. Example:
Standard_D16s_v3 |
Gpu Node Count |
The number of VMs with GPU created to be the agents for the cluster. Designed for ML workloads. If 0, no GPU scale set is created. |
Gpu Node Instance Type |
The type of instances with GPU to be provisioned and to be the agents for the cluster. Example:
Standard_NC12s_v2 |
SQL new or existing |
Parameter indicating whether the SQL Server used for the deployment should be created or it's already existing. Please see here for SQL server requirements. |
SQL Server FQDN or IP |
FQDN or IP associated with the SQL Server. This is only used if the
SQLNewOrExisting parameter is set to existing.
SQL Admin Username |
SQL Server user login. If the
SQLNewOrExisting parameter is set to existing, this is the user for the existing SQL server. Otherwise, this username will be set on the SQL server created. For details
on the required permissions, see our documentation for permissions.
SQL Admin Password |
SQL Server user password. If the
SQLNewOrExisting parameter is set to existing, this is the user password for the existing SQL server. Otherwise, this password will be set on the created SQL server.
UiPath Admin Username |
The admin username to be set on all nodes. This is also used as the host tenant admin. |
UiPath Admin Password |
The password for the node admin user. This is also used as the host tenant admin password. |
Vm Admin Username |
The admin username to be used in the virtual machine instances. |
Vm Admin Password |
The admin password to be used in the virtual machine instances. |
Services Install flags (multiple) |
Choose if the specific service is installed in the cluster. |
Tags by resource |
[OPTIONAL] Tags per resource. Can be empty or have the following format:
{ "Microsoft.Web/serverFarms": { "<TagName>": "<TagValue>" }, "Microsoft.Insights/components": { "<TagName>": "<TagValue>"
