- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
SQL database requirements, supported versions, and per-product database configuration options in Automation Suite.
Databases
- Only Microsoft ODBC Driver 17 is supported.
- Automation Suite versions 2.2510.0 and higher are compatible with SQL versions 2019 and higher.
Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
Each product in Automation Suite requires its own SQL database with corresponding specifications.
By default, the installer creates all the databases for you during the installation process. You must provide the necessary permissions for the installer to do so on your SQL server.
Alternatively, you can create your own databases. The following table lists the database names and their corresponding formats.
| Product / service | Default database name | Connection string format |
| Shared Platform Capabilities | AutomationSuite_Platform | ADO.NET |
| Orchestrator | AutomationSuite_Orchestrator | ADO.NET |
| Action Center | AutomationSuite_Orchestrator | ADO.NET |
| Automation Suite Robots | AutomationSuite_Orchestrator | ADO.NET |
| Automation Hub | AutomationSuite_Automation_Hub | ADO.NET |
| Automation Ops | AutomationSuite_Platform | ADO.NET |
| Data Service | AutomationSuite_DataService | ADO.NET |
| Insights | AutomationSuite_Insights | ADO.NET |
| Test Manager | AutomationSuite_Test_Manager | ADO.NET |
| AI Center | AutomationSuite_AICenter | JDBC |
| Apps | AutomationSuite_Apps 1 | ODBC |
| Document Understanding | AutomationSuite_DU_Datamanager | ODBC PYODBC |
| Process Mining2 | AutomationSuite_ProcessMining_Metadata AutomationSuite_ProcessMining_Warehouse3 AutomationSuite_Airflow4 | ADO.NET PYODBC PSYCOPG2 |
| Solutions | AutomationSuite_AutomationSolutions | ADO.NET |
1 The password for the Apps database must not contain #{.
2To minimize latency issues, it is strongly recommended to deploy the Process Mining databases in the same region as the compute resource (Kubernetes cluster).
3AutomationSuite_ProcessMining_Warehouse uses both ADO.NET and PYODBC formats.
4AutomationSuite_Airflow PostgreSQL database uses SQLAlchemy connection string format. The connection to the AutomationSuite_Airflow database can not begin with a { character.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
You can also use the databases in an elastic pool for better cost-effectiveness.
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, or ODBC passwords as follows:
- for SQL: add
'at the beginning and end of the password, and double any other'. - for JDBC/ODBC: add
{at the beginning of the password and}at the end, and double any other}.
If your password contains reserved URL characters, replace each special character with its percent-encoded equivalent in the connection string. For example, if your password is P@ssw0rd#1!, you must encode it as P%40ssw0rd%231%21.
SQL collation
Automation Suite supports SQL collation set to SQL_Latin1_General_CP1_CI_AS at both the server and database level. We strongly recommend this particular setup for optimum performance and stability.
While you have the flexibility to use a collation of your choice, be aware that untested configurations can potentially lead to unexpected issues.
We do not recommend using Binary SQL or any collations that are case-sensitive, as they cause known issues while installing Automation Suite.
Permissions
If you want the installer to create a database on the provided SQL server, make sure to grant at least the dbcreator role to the SQL account used to connect to the database.
If you want to create your own databases for all the products, you must grant the SQL account the db_owner role for all Automation Suite databases.
If security restrictions do not allow the use of db_owner, then the SQL account must have the following roles and permissions on all databases (the only exception is Insights which still requires db_owner).
db_securityadmindb_ddladmindb_datawriterdb_datareaderEXECUTEpermission on dbo, dt, authz, and msgbus schema
The db_securityadmin and db_ddladmin roles are only required during installation or when databases are reprovisioned; you may revoke them afterwards.
SQL server ciphers
Only the listed SQL ciphers are supported in Automation Suite:
TLS_AES_256_GCM_SHA384TLS_CHACHA20_POLY1305_SHA256TLS_AES_128_GCM_SHA256TLS_AES_128_CCM_SHA256ECDHE-ECDSA-AES256-GCM-SHA384ECDHE-RSA-AES256-GCM-SHA384ECDHE-ECDSA-CHACHA20-POLY1305ECDHE-RSA-CHACHA20-POLY1305ECDHE-ECDSA-AES256-CCMECDHE-ECDSA-AES128-GCM-SHA256ECDHE-RSA-AES128-GCM-SHA256ECDHE-ECDSA-AES128-CCMECDHE-ECDSA-AES128-SHA256ECDHE-RSA-AES128-SHA256ECDHE-ECDSA-AES256-SHAECDHE-RSA-AES256-SHAECDHE-ECDSA-AES128-SHAECDHE-RSA-AES128-SHAAES256-GCM-SHA384AES256-CCMAES128-GCM-SHA256AES128-CCMAES256-SHA256AES128-SHA256AES256-SHAAES128-SHADHE-RSA-AES256-GCM-SHA384DHE-RSA-CHACHA20-POLY1305DHE-RSA-AES256-CCMDHE-RSA-AES128-GCM-SHA256DHE-RSA-AES128-CCMDHE-RSA-AES256-SHA256DHE-RSA-AES128-SHA256DHE-RSA-AES256-SHADHE-RSA-AES128-SHAPSK-AES256-GCM-SHA384PSK-CHACHA20-POLY1305PSK-AES256-CCMPSK-AES128-GCM-SHA256PSK-AES128-CCMPSK-AES256-CBC-SHAPSK-AES128-CBC-SHA256PSK-AES128-CBC-SHADHE-PSK-AES256-GCM-SHA384DHE-PSK-CHACHA20-POLY1305DHE-PSK-AES256-CCMDHE-PSK-AES128-GCM-SHA256DHE-PSK-AES128-CCMDHE-PSK-AES256-CBC-SHADHE-PSK-AES128-CBC-SHA256DHE-PSK-AES128-CBC-SHAECDHE-PSK-CHACHA20-POLY1305ECDHE-PSK-AES256-CBC-SHAECDHE-PSK-AES128-CBC-SHA256ECDHE-PSK-AES128-CBC-SHARSA-PSK-AES256-GCM-SHA384RSA-PSK-CHACHA20-POLY1305RSA-PSK-AES128-GCM-SHA256RSA-PSK-AES256-CBC-SHARSA-PSK-AES128-CBC-SHA256RSA-PSK-AES128-CBC-SHA
SQL requirements for Full-Text Search
Document Understanding requires the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Document Understanding.
For more info, check this guide on how to add/install features on SQL server. You can also find a full list of SQL Server components, which includes Full-Text Search.
SQL requirements for Insights
Insights does not support Azure AD authentication. If you authenticate using Azure AD, dashboards cannot be loaded and data cannot be fetched from the Microsoft SQL database.
Insights requires SQL Server 2019 or 2022, including support for columnstore index and .json functions. SQL Server Enterprise is recommended due to more efficient threading and scalability.
For Azure SQL, ensure the database is S3 service objective or higher.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to View or Change the Compatibility level of a Database - SQL Server.
The installation validates both conditions and alerts you if minimum requirements are not met.
SQL requirements for Data Service
If you create your own database, make sure to grant the following Data Service permissions to your users:
db_ddladmindb_datareaderdb_datawriter
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};
SQL requirements for Process Mining
In Automation Suite versions 2.2510.0 and 2.2510.1, you cannot use a custom database name for the Platform database if Process Mining is enabled. If you specify a custom name, the OMS backfill job fails.
To avoid this, use AutomationSuite_Platform as the Platform database name when installing Process Mining.
When you enable Process Mining for installation on Automation Suite, you must bring a PostgreSQL database for AutomationSuite_Airflow. PostgreSQL is the only supported database type for AutomationSuite_Airflow.
Before installing or upgrading to Automation Suite 2.2510 or higher, you need to manually create the PostgreSQL database for AutomationSuite_Airflow. The PostgreSQL database for Airflow will not be created automatically by the installer.
When migrating from Microsoft SQL Server to PostgreSQL, data migration is not required. With a correct configuration setup, the database is rebuilt when running Sync Airflow.
Supported PostgreSQL versions
PostgreSQL versions 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance.
Hardware requirements
The machine on which the PostgreSQL database for Airflow is installed must meet the following harware requirements.
- Cores: 4
- Memory: 16 GiB
- Storage: 128 GiB
- IOPS: >=500 IOPS
Required permissions
The PostgreSQL Airflow user (or any dedicated database user) must have
- "All Privileges" permissions for the designated Airflow database.
- "all grants" on the server's public schema.
- "search_path" set to "public".
You may need to update PostgreSQL Host-Based Authentication file pg_hba.conf to add the Airflow user to the database access control list and reload the database configuration to apply the changes.
The following code shows an example for setting up a PostgreSQL database.
CREATE DATABASE airflow_db
WITH ENCODING 'UTF8'
LC_COLLATE='en_US.UTF-8'
LC_CTYPE='en_US.UTF-8'
TEMPLATE template0;
CREATE USER airflow_user WITH PASSWORD 'airflow_pass';
GRANT ALL PRIVILEGES ON DATABASE airflow_db TO airflow_user;
-- PostgreSQL 15 requires additional privileges:
GRANT ALL ON SCHEMA public TO airflow_user;
TEMPLATE template0;
The following code shows a database encoding validation example.
SELECT pg_encoding_to_char(encoding) AS encoding
FROM pg_database
WHERE datname = 'airflow_db';
FROM pg_database
For details on how to set up a PostgreSQL database for Airflow, refer to the official Airflow documentation.
Default server port
The default server port for Airflow database connections with PostgreSQL is 5432. If you are using the PgBouncer connection pooler, it is common to use port 6432.
The following code blocks show some example connection strings for PostgreSQL using port 5432.
Sample connection string:
postgresql+psycopg2://testadmin:<password>@test-cu231009v3-postgresql.postgres.database.azure.com:5432/automationsuite_airflow
Sample connection string for using Kerberos:
postgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/automationsuite_airflow
Sample connection string for using Managed Identitiy:
postgresql+psycopg2://testmanagedidentity:@test-postgresql-1.postgres.database.azure.com/airflow-ci-sfasaksqacu8524745
The default server port can be configured to use any available port as per your system requirements.
PgBouncer
Since Airflow uses short-lived connections, it is highly recommended to set up PgBouncer. PgBouncer is a lightweight connection pooler for PostgreSQL.
For details on how to set up PgBouncer, refer to the official PgBouncer documentation.
Process Mining on Automation Suite requires a separate Microsoft SQL Server for the AutomationSuite_ProcessMining_Warehouse for data storage for Process Mining process apps.
To ensure proper functioning of Process Mining, it is recommended to use Microsoft SQL Server 2022.
This is an overview of hardware requirements and recommendations for setting up a Microsoft SQL Server database machine for AutomationSuite_ProcessMining_Warehouse.
To calculate the hardware requirements, you need to have an indication of:
- the number of (million) events in your process.
- the number of case and event fields in your output data.
In a development environment, it is recommended to work on a small development dataset with a limited number of records for performance reasons.
You can use the UiPath Automation Suite Install Sizing Calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed. For details, refer to Hardware requirements.
The SQL user used in the connection strings must have the db_securityadmin database-level role both during and post-installation to enable per app security on the Process Mining data warehouse SQL Server. For details, refer to the official Microsoft documentation on Database-level roles and Configuring process app security.
It is recommended to enable case sensitivity in table and column names using the following command:
ALTER DATABASE AutomationSuite_ProcessMining_Warehouse COLLATE SQL_Latin1_General_CP1_CS_AS
This prevents errors when loading data caused by columns with similar names, such as ID and id. It also ensures that textual values differing only in capitalization are treated as distinct. For example:
'activity 1' == 'activity 1''Activity 1' != 'activity 1'
This prevents duplication issues in SQL transformations.
SQL requirements for AI Center
Requirements for AI Center connected to an external Orchestrator
If you install an AI Center that connects to an external Orchestrator, you must ensure you create a new database named AutomationSuite_Platform for AI Events and AI Storage services.
Currently, AI Center requires SQL Server version 2019 and higher to function optimally.
Requirements for AI Center installed on a FIPS 140-2-enabled machine
To install AI Center on a FIPS 140-2-enabled machine, take the following steps:
- Before starting the Automation Suite installation, take the following steps:
Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
nmap -sV -p <port> -vv --script ssl-cert domainnmap -sV -p <port> -vv --script ssl-cert domain
- During the Automation Suite installation, take the following steps:
Append the following values to the AI Center
sql_connection_string_template_jdbcconnection string in thecluster_config.jsonfile:encrypt=true;trustServerCertificate=false;fips=true;.Example:
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"For details on database configuration, refer to Advanced installation experience and Updating the SQL database.
Add the exported cert from step 1.c. to the trust store of the host machine. For details refer to Updating the CA Certificates.
SQL requirements for HA
For a high-availability configuration of your SQL Server, select an Always On availability group. For more info, refer to Overview of Always On availability groups.
SQL requirements for Orchestrator
To increase performance, avoid deadlocks, and prevent dirty reads in SQL, make sure that the READ_COMMITTED_SNAPSHOT option is set to ON.
To process the same queue with multiple robots, and snapshot isolation is turned on, make sure that the ALLOW_SNAPSHOT_ISOLATION option is set to ON.
Use this query to check if READ_COMMITTED_SNAPSHOT and ALLOW_SNAPSHOT_ISOLATION are enabled or disabled:
SELECT is_read_committed_snapshot_on, snapshot_isolation_state FROM sys.databases
WHERE name like 'PLACEHOLDER'
Make sure to replace PLACEHOLDER with your Orchestrator database name.
If the settings are enabled, the returned value will be 1.
If the settings are disabled, the returned value will be 0. Use this query to enable it:
# To enable READ_COMMITTED_SNAPSHOT
ALTER DATABASE <PLACEHOLDER>
SET READ_COMMITTED_SNAPSHOT ON
# To enable ALLOW_SNAPSHOT_ISOLATION
SET ALLOW_SNAPSHOT_ISOLATION ON
Make sure to replace <PLACEHOLDER> with your Orchestrator database name.
If you use different databases for Test Automation and/or Update Server, READ_COMMITTED_SNAPSHOT and ALLOW_SNAPSHOT_ISOLATION must be enabled on those as well.
- Databases
- SQL collation
- Permissions
- SQL server ciphers
- SQL requirements for Full-Text Search
- SQL requirements for Insights
- SQL requirements for Data Service
- SQL requirements for Process Mining
AutomationSuite_AirflowPostgreSQL databaseAutomationSuite_ProcessMining_Warehousedatabase- SQL requirements for AI Center
- Requirements for AI Center connected to an external Orchestrator
- Requirements for AI Center installed on a FIPS 140-2-enabled machine
- SQL requirements for HA
- SQL requirements for Orchestrator
