- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Prerequisites and preparation steps before deploying Automation Suite to AWS Marketplace.
This page lists the steps you need to take before deploying Automation Suite to AWS.
To prevent data loss, ensure the infrastructure you use does not automatically delete cluster disks on cluster reboot or shutdown. If this capability is enabled, make sure to disable it.
Getting started on AWS
The AWS deployment requires a moderate level of familiarity with AWS services.
If you are new to AWS, you can start by reading the following introductory materials to get familiar. They provide basic materials for how to design, deploy, and operate infrastructure and applications on the AWS Cloud.
This deployment also assumes familiarity with AWS Services listed in the Request resources quotas section of this guide. For a detailed diagram and description of the architecture, see:
Creating an AWS account
If you don't already have an AWS account, create one by following the step-by-step instructions. Your AWS account is automatically signed up for all AWS services. You are charged only for the services you use.
Configuring your AWS account
The following sections walk you through the steps you need to take to configure your AWS Account specific to the Automation Suite deployment requirements.
Amazon EC2 key pairs
You need at least one EC2 key pair in the AWS account in the Region where you will deploy the AWS Marketplace offering.
To create a key pair, refer to Amazon EC2 key pairs and Linux instances.
Take note of the key-pair name as it is needed during the deployment.
For testing or evaluation purposes, we recommend creating a new key pair instead of using an existing one.
Valid domain name
This deployment requires you to have established ownership of the parent domain under which the web application will be served. If you want to register a domain, refer to Registering a public domain.
If you have registered the domain using AWS Route 53, then the hosted zone is preconfigured, and no additional configuration is necessary.
Otherwise, you should set up a hosted zone in your AWS account, with the required name server, start of authority, CNAME, and text records. For further details on how to create a public hosted zone, refer to Working with public hosted zones.
To use other DNS provider, leave the hosted zone id parameter empty. This pauses the deployment after the load balancer creation, allowing you to manually configure the DNS. To resume the deployment, search for the WaitConditionHandle resource in the routing stack. The Physical Id of this resource is an URL. Execute a POST request as described here.
Request resource quotas
If necessary, request service quota increases for the following resources. You might need to request increases if your existing deployment currently uses these resources and if the AWS Marketplace deployment could result in exceeding the default quotas. The Service Quotas console displays your usage and quotas for some aspects of some services.
For more information, refer to What is Service Quotas? and AWS service quotas.
| Resource | Requirement |
| VPCs | 1 |
| Subnets | Up to 6 |
| NAT gateways | 2 |
| VPC endpoints | 1 |
| Internet gateways | 1 |
| Elastic IP addresses | Up to 6 |
| AWS Identity and Access Management (IAM) security groups | 1 |
| IAM roles | Up to 7 |
| Auto Scaling groups | Up to 2 |
| Application Load Balancers | Either 0 or 1 |
| Network Load Balancers | Either 1 or 2 |
| Public certificate authorities (CA) | 1 |
| Hosted zone | 1 |
| RDS instances | 1 |
| Bastion hosts | 1 |
| Secrets | 4 |
| Parameters in Parameter Store | 3 |
| SSM documents | Either 0 or 3 |
| Lambda Functions | 3 |
| Instance Profiles | 2 |
| Security Groups | 3 |
Supported AWS regions
In order for the AWS Marketplace deployment to work in a Region other than its default Region, all the services that are part of the deployment must also be supported in that Region.
For an up-to-date list of AWS Regions and the AWS services they support, refer to AWS Regional Services.
Certain Regions are available on an opt-in basis. For more information, refer to Managing AWS Regions.
To test whether a specific Region is supported, you can launch the AWS Marketplace deployment for that Region and, if you get an Unrecognized resource type error, then the deployment is not supported in that Region.
IAM permissions
Before launching the AWS Marketplace deployment, you must sign in to the AWS Management Console with IAM permissions for the resources that the templates deploy. The AdministratorAccess managed policy within IAM provides sufficient permissions, although your organization may choose to use a custom policy with more restrictions.
For more information, refer to AWS managed policies for job functions.
For a complete list of roles and policies that the CloudFormation template creates, refer to Roles and policies.
Connections to external endpoints
The following table describes all the external endpoints that the service interacts with:
| Requirements | Details |
| AWS metadata service | Provides details about your Amazon EC2 instance |
| AWS management APIs | Used via AWS CLI or lambda functions |
| AWS bootstrap archive | Used for services to provision and manage resources. Retrieved from the following URL: https://s3.amazonaws.com/cloudformation-examples/aws-cfn-bootstrap-py3-latest.tar.gz |
| AWS CLI package | Used for the command line interface to interact with AWS services from a machine. You can access the package from the following URL: https://awscli.amazonaws.com/awscli-exe-linux-x86_64.zip |
| AWS SSM Agent | Used for managing instances via remote commands at scale. You can download the agent from the following URL: https://s3.${AWS::Region}.amazonaws.com/amazon-ssm-${AWS::Region}/latest/linux_amd64/amazon-ssm-agent.rpm |
| AWS Cloudwatch Agent | Used for collecting system and application logs for monitoring. You can download the agent from the following URL: https://s3.amazonaws.com/amazoncloudwatch-agent/redhat/amd64/latest/amazon-cloudwatch-agent.rpm |
| Nvidia drivers | Required for GPU-enabled VMs. You can get the drivers from the Nvidia repository. |
| External repository if used | N/A |
| UiPath S3 buckets for templates / lambda functions usage / bash scripts for installation. | N/A |
For more details, refer to Network requirements.
Connecting AI Center to an external Orchestrator
To connect AI Center to an external Orchestrator, you must set Connect AiCenter to an external Orchestrator to true and provide certificates for Orchestrator and Identity to the parameters listed in AWS Marketplace deployment parameters. For details on how to obtain the certificates, refer to Chain certificates.
To encode the certificates in base64 format, run the following commands:
cat orchestrator.cer | base64 | tr -d '\n' > orchestratorCert
cat identity.cer | base64 | tr -d '\n' > identityCert
To register AI Center to the external Orchestrator, you must run this SSM document.
Backing up the cluster
The AWS template allows you to enable a backup at deployment time. By default, the backup interval is set to 90 minutes, and the retention interval is set to 72 hours. You can change the default values post-deployment.
Enabling FIPS 140-2
You can only enable FIPS 140-2 on your machines after completing an Automation Suite installation. For instructions, refer to Security and compliance.
Insights does not support FIPS 140-2, and you must disable it for a successful installation.
- Getting started on AWS
- Creating an AWS account
- Configuring your AWS account
- Amazon EC2 key pairs
- Valid domain name
- Request resource quotas
- Supported AWS regions
- IAM permissions
- Connections to external endpoints
- Connecting AI Center to an external Orchestrator
- Backing up the cluster
- Enabling FIPS 140-2
