Last updated Nov 6, 2025
Patch artifact download links
This page provides the download links for the artifacts required to apply a patch.
2022.10.14 patches
2022.10.14+patch2
sf.tar.gz
To download sf.tar.gz for Automation Suite 2022.10.14+patch2, run the following command:
wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.14+patch2/sf-2022.10.14+patch2.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.14+patch2/sf-2022.10.14+patch2.tar.gz
versions.json
To download versions.json for Automation Suite 2022.10.14+patch2, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2022.10.14+patch2/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2022.10.14+patch2/versions.json
2022.10.14+patch1
sf.tar.gz
To download sf.tar.gz for Automation Suite 2022.10.14+patch1, run the following command:
wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.14+patch1/sf-2022.10.14+patch1.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.14+patch1/sf-2022.10.14+patch1.tar.gz
versions.json
To download versions.json for Automation Suite 2022.10.14+patch1, run the following command:
wget -O versions.json https://download.uipath.com/automation-suite/2022.10.14+patch1/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2022.10.14+patch1/versions.json
DU CJKOCR offline bundle
To download the DU CJKOCR offline bundle for 2022.10.14+patch1, see ML Packages Offline Installation.
  • 2022.10.14 patches
  • 2022.10.14+patch2
  • 2022.10.14+patch1
