- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
To clear all the data stored in Redis and reset it to an empty state, take the following steps:
Identify the secret name, password, and port:
export KUBECONFIG="/etc/rancher/rke2/rke2.yaml"; export PATH=$PATH:/var/lib/rancher/rke2/bin; secretName=$(kubectl get redb redis-cluster-db -o jsonpath="{.spec.databaseSecretName}" -n redis-system) password=$(kubectl get secret $secretName -o jsonpath="{.data.password}" -n redis-system | base64 --decode) port=$(kubectl get secret $secretName -o jsonpath="{.data.port}" -n redis-system | base64 --decode)export KUBECONFIG="/etc/rancher/rke2/rke2.yaml"; export PATH=$PATH:/var/lib/rancher/rke2/bin; secretName=$(kubectl get redb redis-cluster-db -o jsonpath="{.spec.databaseSecretName}" -n redis-system) password=$(kubectl get secret $secretName -o jsonpath="{.data.password}" -n redis-system | base64 --decode) port=$(kubectl get secret $secretName -o jsonpath="{.data.port}" -n redis-system | base64 --decode) -
Identify the service names:
kubectl get secret $secretName -o jsonpath="{.data.service_names}" -n redis-system | base64 --decodekubectl get secret $secretName -o jsonpath="{.data.service_names}" -n redis-system | base64 --decode -
Let's assume the output of the previous command is:
redis-cluster-db, redis-cluster-db-headless. You must call the followingFLUSHALLcommands:kubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db -p $port -a $password FLUSHALL kubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db-headless -p $port -a $password FLUSHALLkubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db -p $port -a $password FLUSHALL kubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db-headless -p $port -a $password FLUSHALL
