- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
If you experience issues with image vulnerabilities or storage consumption after performing an upgrade, you can delete the images from the old installer.
Starting with Automation Suite 2022.10.13, you can clean up the previous version images after the upgrade from the in-cluster Docker registry, using the following commands:
To delete the images that are not needed anymore after upgrade:
cd /opt/UiPathAutomationSuite/<new_version>/installer ./bin/uipathctl registry cleanup --manifest versions/docker-images.jsoncd /opt/UiPathAutomationSuite/<new_version>/installer ./bin/uipathctl registry cleanup --manifest versions/docker-images.json -
To delete the on-demand bundles images, you need to specifically remove these images:
The following example shows the format of the./bin/uipathctl registry cleanup --manifest /versions/docker-images.json --images-list images-list.json./bin/uipathctl registry cleanup --manifest /versions/docker-images.json --images-list images-list.jsonimages-list.jsonfile:{ "cleanup-list": [ "aicenter/python39:23.10.0-rc4", "image2", "image3" ] }{ "cleanup-list": [ "aicenter/python39:23.10.0-rc4", "image2", "image3" ] }
For previous Automation Suite versions, to perform this optional post-upgrade operation, take the following steps:
Update
IMG,TAG,USER,PASS,registry, andlatest_image_jsonaccording to the cluster configuration in the following script, then run it:#!/bin/bash ### Please change below variables as required IMG=<E.g. dataservice/dataservice-designer> TAG=<E.g. v20231116-tag> USER=<E.g. "admin"> PASS=<E.g. "password"> registry=<E.g. "registry.mycluster.com"> latest_image_json=<E.g. "/opt/UiPathAutomationSuite/UiPath_Installer/versions/docker-images.json"> #### [[ -f "${latest_image_json}" ]] || { echo "File "$latest_image_json" doesn't exist" exit 1 } cat "${latest_image_json}" | tr -d '",' | grep -w "${IMG}:${TAG}" >> /dev/null && { echo "Image ${IMG}:${TAG} is being used in cluster. Will skip the deletion." exit 0 } echo "Deleting image ${IMG}:${TAG}" cred="-u ${USER}:${PASS}" for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.layers | .[] | .digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.config.digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done#!/bin/bash ### Please change below variables as required IMG=<E.g. dataservice/dataservice-designer> TAG=<E.g. v20231116-tag> USER=<E.g. "admin"> PASS=<E.g. "password"> registry=<E.g. "registry.mycluster.com"> latest_image_json=<E.g. "/opt/UiPathAutomationSuite/UiPath_Installer/versions/docker-images.json"> #### [[ -f "${latest_image_json}" ]] || { echo "File "$latest_image_json" doesn't exist" exit 1 } cat "${latest_image_json}" | tr -d '",' | grep -w "${IMG}:${TAG}" >> /dev/null && { echo "Image ${IMG}:${TAG} is being used in cluster. Will skip the deletion." exit 0 } echo "Deleting image ${IMG}:${TAG}" cred="-u ${USER}:${PASS}" for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.layers | .[] | .digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done for i in `curl -k -H 'Accept: application/vnd.docker.distribution.manifest.v2+json' $cred "https://$registry/v2/$IMG/manifests/$TAG" | jq -r '.config.digest'`; do curl -k -H "Accept: application/vnd.docker.distribution.manifest.v2+json" $cred -X DELETE "https://$registry/v2/$IMG/manifests/$i" done -
Restart the registry pod for the Garbage Collection execution or execute into the registry pod and run Garbage Collection using the following command:
registry garbage-collect /etc/docker/registry/config.ymlregistry garbage-collect /etc/docker/registry/config.yml
